Broken wing
Old December 22nd 05, 06:18 PM posted to rec.aviation.piloting
Default Broken wing
Matt Whiting wrote:
I said the Electra is not a jet you pompous asshole...
Nice attempt at forging an email from me, but you aren't very good at it.
Matt
Old December 22nd 05, 06:19 PM posted to rec.aviation.piloting
Default Broken wing
Bob Moore wrote:
Matt Whiting wrote
Except the Electra wasn't a jet. Maybe you are thinking of the
Comet.
Well...the Electras that I flew certainly had "jet" engines.
Even burned kerosene. :-)
Gee, Bob, you should know the difference between a turbine engine used
as a propjet from one used as a pure jet. :-)
Matt
Old December 22nd 05, 06:21 PM posted to rec.aviation.piloting
Default Broken wing
Bob has remarkable consistency in posting incisive, telling stuff,
gleaned without doubt over years of flying. Notwithstanding that, don't
you think your invective isn't quite apropos for one past 70?
When he wrote jet under two quotation marks, it was obvious he wasn't
referring to the obvious.
Just my 0.02,
Ramapriya
Old December 22nd 05, 07:11 PM posted to rec.aviation.piloting
Default Broken wing
Bob Moore wrote:
Comet.
Bob Moore
The ones I flew had jet turbine engines but they were geared to propellors
which makes a difference. They are generally referred to as turboprops
whereas the term jet normally refers to a jet engine without external
propellors. But the difference is decreasing since most high-bypass jet
engines now have internal rotors which produce more than half the thrust
using propellor type action but within the engine frame. That air doesn't
even go through the combutions chambers, it bypasses them, hence the term
high-bypass.
But you knew that, Bob, I just mentioned it for those who didn't.
Darrell R. Schmidt
B-58 Hustler History: http://members.cox.net/dschmidt1/
Old December 22nd 05, 08:48 PM posted to rec.aviation.piloting
Default Broken wing
"Stubby" wrote in message
Way back, I believe the first jet passenger jet was the Lockheed Electra.
The first jet airliner was the de Havilland Comet. The Lockheed Electra
you're referring to was a turboprop.
Old December 22nd 05, 11:13 PM posted to rec.aviation.piloting
Default Broken wing
engine used as a propjet from one used as a pure jet. :-)
Hey! Eastern Airlines called them "Prop Jets".
By the definitions posted here, there are no "Jet" airliners
currently flying, since they are all "Turbo Fans". Right??? :-)
Bob Moore
Old December 22nd 05, 11:57 PM posted to rec.aviation.piloting
Default Broken wing
Kev
I'll use your post to add my comments on Electra.
Lockheed fixed the wing problem but bird had the bad name and airlines
didn't want to fly it.
USN bought a bunch (of the fixed birds) and put MAD gear and other
anti sub equipment in and have been flying them for years without any
wing problems.
Due to age and hours, Navy is starting to look at newer birds for
their mission. One being looked at is the 737.
2 more shopping days til Xmas 05 )
Big JOhn
On 22 Dec 2005 07:36:00 -0800, "Kev" wrote:
Electra. The plane mysteriously fell out of the air and very thorough
search for a cause was instituted. In the end, again if I remember
correctly, the conclusion was that the wing spar failed from fatigue
because the wing was nutating, a slight circular motion due to
gyroscopic effects.
To jog your memory:
http://en.wikipedia.org/wiki/Lockheed_L-188_Electra
Maybe that's the same thing caused the FL seaplane crash.
The Electra problem happened pretty soon after they came out. Those
seaplanes have been around a long time.
Cheers, Kev
Old December 23rd 05, 12:15 AM posted to rec.aviation.piloting
Default Broken wing
The still derive significant thrust from the exhaust jet, but I'll grant
you that it is getting much grayer as the bypass ratios keep increasing.
Then again, if it was black and white, what would we have to argue about
here? Things would get dull in a hurry.
Matt
Old December 23rd 05, 03:18 AM posted to rec.aviation.piloting
Default Broken wing
Sounds like you're confusing it with the DeHaviland Comet. The cause was
eventually determined to be the rapid formation of stress cracks around the
corners of the rectangular cabin windows.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old December 23rd 05, 03:36 AM posted to rec.aviation.piloting
Default Broken wing
They also used a high pressure sea level cabin, modern
pressurized aircraft use a lower differential pressure,
maybe 8-9 PSI for a 9,000 foot cabin at max cruise altitude.
The Comet was a victim of design, fabrication and
operational methods.
James H. Macklin
ATP,CFI,A&P
Merry Christmas
Have a Safe and Happy New Year
Live Long and Prosper
Jim Macklin
"George Patterson" wrote in message
news:U7Jqf.50934$CL.50059@trnddc04...
Lockheed
very thorough
The cause was
cracks around the
| George Patterson
rights belong to
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 03:54 AM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 04:52 AM
