Broken wing
Old December 22nd 05, 02:56 PM posted to rec.aviation.piloting
Default Broken wing
Way back, I believe the first jet passenger jet was the Lockheed
Electra. The plane mysteriously fell out of the air and very thorough
search for a cause was instituted. In the end, again if I remember
correctly, the conclusion was that the wing spar failed from fatigue
because the wing was nutating, a slight circular motion due to
gyroscopic effects.
Maybe that's the same thing caused the FL seaplane crash.
Old December 22nd 05, 04:36 PM posted to rec.aviation.piloting
Default Broken wing
gyroscopic effects.
To jog your memory:
http://en.wikipedia.org/wiki/Lockheed_L-188_Electra
The Electra problem happened pretty soon after they came out. Those
seaplanes have been around a long time.
Cheers, Kev
Old December 22nd 05, 04:45 PM posted to rec.aviation.piloting
Default Broken wing
"Stubby" wrote in message
gyroscopic effects.
The Electra wasn't a jet, it was a turbopropeller. Furthermore, the
Electra's design flaw was discovered early in it's life cycle. Grumman
Mallards are a mature design of 70 years starting with the Goose.
D.
Old December 22nd 05, 05:30 PM posted to rec.aviation.piloting
Default Broken wing
gyroscopic effects.
Except the Electra wasn't a jet. Maybe you are thinking of the Comet.
Matt
Old December 22nd 05, 05:51 PM posted to rec.aviation.piloting
Default Broken wing
Comet.
Well...the Electras that I flew certainly had "jet" engines.
Even burned kerosene. :-)
Bob Moore
Default Broken wing
Hi I'm lonely, and I want my mommy...
Old December 22nd 05, 05:54 PM posted to rec.aviation.piloting
Default Broken wing
I said the Electra is not a jet you pompous asshole...
Old December 22nd 05, 06:01 PM posted to rec.aviation.piloting
Default Broken wing
gyroscopic effects.
To jog your memory:
Excellent article! Thanks. That Electra (maybe there are others) was
a turboprop rather than a turbojet as I had assumed.
Old December 22nd 05, 06:08 PM posted to rec.aviation.piloting
Default Broken wing
gyroscopic effects.
The Electra did, however, have a string of catastrophic early failures,
which were eventually traced to metal fatigue in the wing or fuselage
structure caused by a vibration or oscillation that occurred in flight
and was associated with the design of the plane; and the Comet had a
series of catastrophic early failures which were eventually traced to
metal fatigue and crack grown around the windows occurring after
multiple pressurization and depressurization cycles. Both were prime
examples of the learning process associated with civil aviation and
aviation technology.
Am I recalling this correctly?
Old December 22nd 05, 06:17 PM posted to rec.aviation.piloting
Default Broken wing
Are you thinking the English Comet? It had several inflight mysterious
breakups before it was discovered that the square windows created
stress fractures after several pressurization cycles. I believe it was
the first pax airline.
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 03:54 AM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 04:52 AM
