The engine is finally back!
Old December 22nd 05, 06:23 PM posted to rec.aviation.owning
Default The engine is finally back!
At Oshkosh this year the people at the Lycoming booth swore it would
take only two weeks, but when the actual paperwork arrived everything
said one month in the shop. It ended up taking a little over a month,
from the day it was crated by my mechanic to the day it was returned.
You've never been lied to before? You dumbass MoFo.
I don't know that he was lied to. You got to figure it took a week to get
from him to them and then a week from them to him. That means the work took
2 weeks.
Old December 22nd 05, 08:08 PM posted to rec.aviation.owning
BT,
Can I ask how much the OH cost at your local shop? I'm always interested
for when the day comes we'll have to OH one of ours.
Thanks
"BTIZ" wrote in message
news:6qnqf.6557$LB5.5831@fed1read04...
I'll echo that... we did an overhaul by a local shop. Piper Pawnee
O-540-235HP with STC to 250HP
He did his normal run at the shop.. then once installed.. it was a quick
(short) static run (mag check) to check oil pressures and leaks.. then
shut
down inspect...
Then it was start and go.. no ground time.. it was 100F out and we did not
want to overheat on the ground... FULL Power climb to 10,000MSL where the
outside temps were cooler and we could run it full throttle at cruise.
Stayed there for 1+30 monitoring oil temp and pressure (no CHT available).
A few more flights at altitude to accumulate about 5 hours total before
putting it to work, glider tow.
Over 55 hours on the engine now and just swapped from Mineral to regular
AD.
All appears well.
BT
"dlevy" wrote in message
news
Same here.
"Paul kgyy" wrote in message
snip
I did my first 30 minutes orbiting the airport with tower permission.
Old December 22nd 05, 09:38 PM posted to rec.aviation.owning
In article 6qnqf.6557$LB5.5831@fed1read04,
When I was member of a local club full of old pilots, they had a cilinder
crack on a 0-300 form a C172B. They pulled the cilinders, topped it and
then proceeded to 'break it in' by insisting on reduced power for the next
100hours...
I quit that club and joined another.
Eduardo K. | Darwin pone las reglas.
http://www.carfun.cl | Murphy, la oportunidad.
http://e.nn.cl |
| Yo.
Old December 23rd 05, 12:41 AM posted to rec.aviation.owning
They actually told me two weeks total- from the day it was shipped to the
Old December 23rd 05, 06:27 AM posted to rec.aviation.owning
I'd have to check with the treasurer... but I think the shop price came
close to $19K.. plus we did out own "in house" labor for the R&R, plus new
braided oil lines..
BT
"Jim Burns" wrote in message
BT,
Thanks
shut
down inspect...
not
available).
AD.
All appears well.
BT
news
Same here.
snip
Old December 23rd 05, 02:52 PM posted to rec.aviation.owning
Thanks
news:KTLqf.13950$LB5.5023@fed1read04...
braided oil lines..
BT
BT,
interested
Thanks
quick
shut
down inspect...
not
available).
regular
AD.
All appears well.
BT
news Same here.
snip
permission.
Old December 23rd 05, 06:41 PM posted to rec.aviation.owning
"Viperdoc" wrote in message
news
Well they were idiots for saying that and you have every right to be ****ed.
I assume you or they didn't ship the engine one or two day air. They really
should quote "time in the shop". It's not like they can control how long it
takes to ship.
Old January 15th 06, 07:05 PM posted to rec.aviation.owning
Well, glad to hear it's still doing OK, but in a normally aspirated
engine, you're not gonna' make the higher power settings you need for a
good breakin at 10,000msl. You're prolly not going to be able to make
much more than 55% power, even *at* full throttle.
Would have been better to stay lower where you could make 65-75% power
with that engine during those critical, first break-in hours.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Chevy LS2 and Trans??? any real issues besides weight MrV Home Built 82 November 18th 05 04:11 AM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 02:09 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
