The engine is finally back!
Old December 21st 05, 04:43 AM posted to rec.aviation.owning
Default The engine is finally back!
After sending my Lycoming AEIO-540 to the factory for a mandatory repair it
has finally returned. At Oshkosh this year the people at the Lycoming booth
swore it would take only two weeks, but when the actual paperwork arrived
everything said one month in the shop. It ended up taking a little over a
month, from the day it was crated by my mechanic to the day it was returned.
Lycoming says they will pay for the costs of removing and remounting the
engine, along with the shipping as well as the repairs. Mine only had a
little over 300TT. I guess they figure the costs of the new crankshafts as
well as the repairs for all of the engines would be a lot cheaper than
series of very expensive product liability lawsuits!
Anyway, it looks like it'll need mineral oil for a while, and then there's
also the risk of something else working loose or breaking after the removal
and install- we'll have to wait and see in this regard. I may take it and
run it hard for a few hours, and then take it back to the mechanic to pull
the cowling and make sure everything stayed tight.
I've heard a lot of different advice on breaking in a new engine- run at
full power, don't run at any power for a long period of time, vary the power
settings (MP and prop), etc. Any advice? When do you switch back to regular
detergent oil?
Old December 21st 05, 04:49 AM posted to rec.aviation.owning
detergent oil?
Lycoming should have sent a copy of their recommended procedure with
the engine. If not, I'd get on them to give you a set of guidelines so
that if there is a failure during the breakin period they can't tell
you that you used the incorrect procedure.
Craig C.
Old December 21st 05, 03:24 PM posted to rec.aviation.owning
As others have said, follow the Lycoming recommendations to the letter.
It will involve high power settings until the rings seat (assuming you
have new rings) and you will use mineral oil until that happens. The
event will declare itself with lower CHT and reduced oil consumption.
I did my first 30 minutes orbiting the airport with tower permission.
Old December 21st 05, 04:18 PM posted to rec.aviation.owning
Glad you got it back! Hopefully it will be a smooth install and no future
problems.
Google "Lycoming engine break in " and you'll get several hits directly from
Lycoming's site regarding break in. If there is any warranty remaining, I
would call Lycoming and ask them directly, then document the call and their
advise. (just in case)
Congrats. Glad you got it back.
"Viperdoc" wrote in message
it
booth
returned.
removal
power
regular
detergent oil?
Old December 21st 05, 04:23 PM posted to rec.aviation.owning
Same here.
"Paul kgyy" wrote in message
snip
Old December 22nd 05, 02:37 AM posted to rec.aviation.owning
I'll echo that... we did an overhaul by a local shop. Piper Pawnee
O-540-235HP with STC to 250HP
He did his normal run at the shop.. then once installed.. it was a quick
(short) static run (mag check) to check oil pressures and leaks.. then shut
down inspect...
Then it was start and go.. no ground time.. it was 100F out and we did not
want to overheat on the ground... FULL Power climb to 10,000MSL where the
outside temps were cooler and we could run it full throttle at cruise.
Stayed there for 1+30 monitoring oil temp and pressure (no CHT available).
A few more flights at altitude to accumulate about 5 hours total before
putting it to work, glider tow.
Over 55 hours on the engine now and just swapped from Mineral to regular AD.
All appears well.
BT
"dlevy" wrote in message
news
Same here.
snip
Old December 22nd 05, 04:41 AM posted to rec.aviation.owning
Before starting the last engine I put together, I borrowed a oil pressure
pot to fill the galleys.
Attached at the oil pressure takeoff and pushed oil in by air pressure
before the first start.
Used a quart or so. It not only fills the galleys but also pumps up the
lifters.
Engine fired on the 2 blade and ran smooth!
Kent Felkins
Tulsa
it
booth
returned.
removal
power
regular
detergent oil?
Old December 22nd 05, 05:38 AM posted to rec.aviation.owning
I did something similar when I replaced the engine in a van I owned long ago. I
scavenged an empty freon tank, removed the valve, and poured four quarts of oil
into it with a funnel (seemed to take forever). Then I put the valve back in and
hooked it up to an air compressor. Once I got it pressurized, I turned it upside
down, hooked it up to the hole for the oil pressure sending unit, and opened the
valve.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old December 22nd 05, 06:01 PM posted to rec.aviation.owning
At Oshkosh this year the people at the Lycoming booth swore it would take only two weeks, but when the actual paperwork arrived everything said one month in the shop. It ended up taking a little over a month, from the day it was crated by my mechanic to the day it was returned.
You've never been lied to before? You dumbass MoFo.
Old December 22nd 05, 06:05 PM posted to rec.aviation.owning
valve.
Probably think you're clever don't you asshole?
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Chevy LS2 and Trans??? any real issues besides weight MrV Home Built 82 November 18th 05 04:11 AM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 02:09 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
