A-6 crash after launch?
Old May 27th 06, 10:34 PM posted to rec.aviation.military.naval
Default A-6 crash after launch? OBTW
"John Carrier" wrote...
One of the peculiarities of the A-6 was its lack of a command ejection system.
There was some kind of reverse (perverse) logic in the community that had
sufficient following to keep it that way (IIRC) for the life of the aircraft.
Part of it had to do with the lack of automatic canopy sequencing. You could go
through the canopy or after the canopy, but not while it was in transit (because
of the forward bow). If one Crewmember hit the canopy jettison while the other
pulled the ejection handle, it was bad news for at least one of them -- both if
the canopy got hung up on the first seat...
IIRC, command ejection was part of the A-6F proposal.
Old May 28th 06, 12:27 AM posted to rec.aviation.military.naval
They had some footage of some cat launches gone wrong. In one an A-6 took
off the waist catapult of a carrier and started losing altitude almost
immediately. Then something really big fell off the plane, it started to
roll, and the pilots ejected at very low altitude.
The pilot was Rick "Twig" LaBranche, who is now a CDR and has the
distinction of being the CO of the last operational Tomcat squadron (VF-31
flying F-14Ds at least until September).
_____________
José Herculano
Old May 28th 06, 04:47 AM posted to rec.aviation.military.naval
"Allen Epps" wrote in message
This the S-1 video through the wave you were looking at?
http://tinyurl.com/jjjo5
Pugs
I assume that the S-1 did not have ejection seats?
JD
Old May 28th 06, 05:03 AM posted to rec.aviation.military.naval
"Allen Epps" wrote...
I've seen an A-7 launch through a similar wave off Midway in the northern
Pacific. I think we were all surprised when he flew out the other side!
Old May 28th 06, 05:26 AM posted to rec.aviation.military.naval
"John Weiss" jrweiss98155nospamatnospamcomcastdotnospamnet wrote in
message ...
I was just thinking the S-1 was lucky they had recips. I thought for sure a
jet would flame out!
Old May 28th 06, 01:27 PM posted to rec.aviation.military.naval
message ...
system. There was some kind of reverse (perverse) logic in the community
that had sufficient following to keep it that way (IIRC) for the life of
the aircraft.
could go through the canopy or after the canopy, but not while it was in
transit (because of the forward bow). If one Crewmember hit the canopy
jettison while the other pulled the ejection handle, it was bad news for
at least one of them -- both if the canopy got hung up on the first
seat...
I think a canopy interlock would have been simple to engineer. Certainly
part of the engineering to retrofit command ejection.
R / John
Old May 28th 06, 03:20 PM posted to rec.aviation.military.naval
What is (was) an S-1?
From the web:
The skipping of the P-1 designation in the 1962 Joint designation scheme
was most likely due to the fact that it was convenient to redesignate the
P2V, P3V, P4Y, and P5M to P-2, P-3, P-4, and P-5, respectively. 28. Similar
to note 27, the S-1 designation was most likely skipped out of the
convenience of renaming the S2F to S-2 and continuing from there.
Bob Moore
S-2F NAS Kingsville 1959
Old May 28th 06, 04:27 PM posted to rec.aviation.military.naval
On 5/27/06 6:58 AM, in article , "John
Carrier" wrote:
"DDAY" wrote in message
. net...
I was watching a documentary called "Top Gun" on the Military Channel.
Probably engine failure on the stroke. Possibly wrong weight setting on the
cat. The older catapults would use a given steam pressure to achieve a
particular end-speed for a particular gross weight. These would malfunction
on rare occasions. The newer cats use a rotary valve that allows full
pressure (600psi IIRC) for a particular duration and are just about fool
proof (unless its set for the wrong weight).
A fully-loaded A-6 didn't have very good single-engine fly away capability.
The "something" was probably all the underwing stores. Pilot pushed the
emergency jettison and the pylons were cleaned off.
You're right, John. It was a single engine failure on the stroke. Pilot
gets a full chute. B/N skips off the water. Both live.
Max thrust
Gear up
Stores jettison
Bleed Air Gang Bar - OFF
Establish 19 unit climb in balanced flight...
First five steps of the engine failure procedure from memory after a 10 year
hiatus.
If you didn't get those steps done IMMEDIATELY, you didn't stand much of a
chance of bringing the jet back. Later, an east coast squadron discovered
in Fallon in a tanker that even if you DID get those steps done, they jet
could be un-flyable single engine. The engines had de-tuned over time
making the single-engine performance charts incorrect. Pax re-vamped them
in about 1994-5.
--Woody
On 5/27/06 5:27 PM, in article ,
_____________
José Herculano
Twig's STILL CO? I would have thought that he was done by now.
--Woody
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 7th 06 12:13 AM
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 06:58 PM
spaceship one Pianome Home Built 169 June 30th 04 06:47 AM
