Removing oil galley plug
Old November 7th 06, 12:35 AM posted to rec.aviation.owning
Drew Dalgleish
Default Removing oil galley plug
Kroil probably won't work if it has never seize on the threads but it
can't hurt to try. If it's really stuck it's probably faster to pull
the prop and ring gear than to mess things up trying to work around
it. Flying long enough to get the case fully warmed up may help too.
Thanks for the offer, but I'm in Wisconsin. Getting anything "straight on"
to the plug is going to require pulling the front engine baffle, and even
then the ring gear may be in the way, so for now, it's going to wait while I
finish the rest of the install and collect more insight on the problem.
"Robert M. Gary" wrote in message
BTW: I can't remember if you're one of us from Sacramento or not. After
our initial failed attempt to remove the plug we took it to a guy who
teaches and lives next to Sacramento Community College Aviation (at
Exec Airport). He used the EZ-out from his fly-in driveway.
Email me if you want his info.
-Robert
Jim Burns wrote:
For those who have installed oil temp probes in the forward oil galley
of
their Lycoming engines, how did you or your A&P remove the 1/8" NTP
plug?
I've got one that is stuck tight and I don't want to booger anything up
trying to get it out. I've heard horror stories of people having to
drill
them out because they are stuck but I'm wondering if an impact driver
could
be used without causing any damage to the case.
Any experience or thoughts would be appreciated.
Old November 7th 06, 02:58 AM posted to rec.aviation.owning
David Lesher
"nrp" writes:
I'm not a fan of EZ-outs for something that is extra tight, as you may
end up distorting the threads in the case.
Nor am I; an EXZout is for when the head is stripped.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
  #24
Old November 7th 06, 05:17 AM posted to rec.aviation.owning
David Lesher
Nor am I; an EZout is for when the head is stripped.
Boy was this unclear....
You use an EZout when the head of the screw/bolt is damaged.
Classic -- phillips head screws.
It's of little use if the screw/bolt is really stuck. You can drill
such out but it's a PITA.
  #26
Old November 7th 06, 04:01 PM posted to rec.aviation.owning
: Not NeverSeize but pipedope, but I tend to agree. Another trick that
: comes to mind is a large American Beauty soldering iron applied to
: the plug, getting it hot enough to disrupt the pipe dope. (The iron
: will not melt the case so that's no worry.)
: You are better off heating the crankcase area with a heat gun and
: turning the plug with the Allen wrench. Heating the plug will just
: expand the plug into the case, whereas heating the case will expand the
: aluminum away from the plug.
Or a corollary might be to run the engine long enough to heat the case and
then apply ice or dry ice only to the plug.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
  #28
Old November 7th 06, 04:20 PM posted to rec.aviation.owning
David Lesher
Orval Fairbairn writes:
You'd think so, but what you are doing with the iron is two things:
a) Trying to overheat and destroy the pipe dope. (Then drip in some
Kroil...)
b) Breaking the bond between the plug and case.
Many a time I've gotten a bolt out by heating it orange with the
Ox-Acy torch. You'd think it would make life worse, but...
[Obviously, you do not want to torch the aluminum case.....]
  #29
Old November 7th 06, 04:40 PM posted to rec.aviation.owning
Orval Fairbairn wrote:
David Lesher wrote:
(Drew Dalgleish) writes:
Lycoming typically uses Teflon pipe sealant on those plugs,
and with age and heat the stuff sets and gets really stubborn.
Heating the entire area or just the plug itself will usually
work. The trick is to let the thing sit for a minute after heating; the
plug and case will come to the same temperature, and since aluminum
expands at twice the rate of steel for a given rise in temperature, the
plug will loosen slightly. More effective than the loosening will be
the relaxing of the grip of the teflon dope. I used to rebuild air
compressors that often had steel plugs in aluminum, and we used to
torch just the plug, let it sit, then back it out. The biggest risk
with this was the tearing out of the aluminum threads, especially with
the softer casting aluminums.
That said, there have been times I haven't been able to get
plugs or other fittings out of the engine core when installing a new
one, and rather than risk damaging the core ($$$) we put in a new
fitting and let Lycoming fuss with getting the old one out. This
doesn't help your situation. The casting around those plugs is rather
massive and will soak up an awful lot of heat before the temp will rise
much, and there's a risk of overheating the case in trying to get the
plug warmed up.
I noticed that the JPI probe has a 3/8"-24 thread on it, which
they claim is a match for the 1/8" pipe thread. This isn't true; it may
fit, but it could damage the threads, because 1/8" pipe has a 27 tpi
thread and is tapered. You sure won't want to force it in too far. Most
people massively overtorque pipe fittings, far beyond what's necessary
to keep them there; the spec is quite low and should be used. We used
to get a lot of compressors and control valves back with split pipe
bosses from overtorquing. Somehow the mechanics felt that the air or
coolant was going to push that plug out unless it was supertight.
Dan
  #30
Old November 7th 06, 05:29 PM posted to rec.aviation.owning
David Lesher
"pbc76049" writes:
I had a real tough plug to pull once. I JB welded the allen wrench into the
socket
and it cane out with little fuss after massaging the case with a heat gun to
250f
measured with my trusty IR temp gage.........
This was my next suggestion.
Fouled plug IO 470 [email protected] General Aviation 7 January 29th 06 07:03 PM
Plug fouled Denny Owning 9 September 2nd 05 06:58 AM
Plug replacements for O-360-A3A [email protected] Owning 3 August 20th 05 11:39 PM
ICOM Headset Adaptor Plug Ron Wanttaja Home Built 3 June 2nd 05 08:54 AM
Helicopter headset plug - help needed NewsGroups Home Built 4 September 8th 04 06:21 PM
