ICOM Headset Adaptor Plug
Old May 31st 05, 04:47 PM
Default ICOM Headset Adaptor Plug
I've picked up an ICOM IC-A5 handheld that I'm going to install into the
avionics panel of my Fly Baby as a semi-fixed installation. I picked up a
headset adaptor for it, but I don't like having those big clunky headset plugs
as intermediate connectors. I want to implement Jim Weir's "Karmic connector"
concept, but if I do that, the radio install will involve five connector sets.
What I'd prefer is to wire up my own adaptor to the radio. However, I'm having
a devil of a time finding the right plug that fits into the headset adaptor plug
on the radio. To the eye, it appears to be a 3.5 MM plug similar to the
standard 1/8" walkman headset plugs, except its four conductor. I found such a
plug at the local electronics store, but it only fits in the radio a bit less
than halfway. Visually, it looks dead-on, but apparently is slightly larger
diameter once one gets past the tip. Nokia cell phones have four-conductor
plugs, but they're a bit smaller.
I'm loath to cut up my current headset adaptor, since I'd like to keep it as a
backup and the blessed things cost $60 each.
So: Any idea where I can find a plug? ICOM doesn't list the plug alone on
their web page, nor do they provide the connector ID.
Old June 1st 05, 02:38 AM
Rob Cherney
On Tue, 31 May 2005 07:47:10 -0700, Ron Wanttaja
Google is your friend:
http://www.gigaparts.com/parts/profi...sku=ZCB23003-3
http://www.durhamradio.com/s/custome...at=1658&page=1
http://www.rtsars.com/othercables_template.cfm
http://ttl2usb.com/order.html
Rob-
Robert Cherney e-mail: rcherney(at)comcast(dot)net
Old June 1st 05, 04:00 AM
Thanks much for the links! I'd done searches with all the keywords I could
think of, but certainly didn't come up with these good sites.
My only concern is whether their 3.5MM plugs will fit the ICOM...as I mentioned,
a plug bought at the local electronics emporium did not. But with RT Systems
offering not only a right-angle plug AND with the wires already attached, I'll
risk the $8. :-)
Old June 2nd 05, 08:54 AM
Newsgroups
They are the same plugs as used on camcorders.... just buy a camcorder
lead for $5 and cut up the leads, the advantage is its a molded plug
that is professionally done.
risk the $8. :-)
Panther C.A.T. headset. Ross Taylor Products 0 October 23rd 04 12:59 AM
Icom IC-A5/23 and David Clark Thomas Schmidt Piloting 5 August 16th 04 10:45 PM
Bose makes good on my wife's headset. Kyler Laird General Aviation 3 March 10th 04 03:08 PM
Bose makes good on my wife's headset. Kyler Laird Piloting 3 March 10th 04 03:08 PM
Icom CM-35 Desktop Battery Charger for Icom IC-A2 Radio A. Kay Aviation Marketplace 0 August 23rd 03 09:01 AM
