#11
The unit won't see other transponders, unless the other transponder is interrogated by a TCAS-equipped aircraft. Correct except for the last 4 words. ATC radar also intrerrogats transponders. Tony V. http://home.comcast.net/~verhulst/SOARING |
Tony Verhulst wrote: The unit won't see other transponders, unless the other transponder is interrogated by a TCAS-equipped aircraft. Correct except for the last 4 words. ATC radar also intrerrogats transponders. Note that I was responding to a poster discussing what happens when you are below radar coverage. -- Bob Noel (goodness, please trim replies!!!) |
Andrew,
Do they work when there is no radar facility nearby, or you are below the radar altitude? Your targets must be hit by radar (or an active TCAS from an airliner), not yourself. If that doesn't happen, the units don't work. How much traffic will there be in such areas? -- Thomas Borchert (EDDH) |
Bob Noel wrote:
Note that I was responding to a poster discussing what happens when you are below radar coverage. Missed that. Thanks for the correction. Tony |
Our club, Black Forest Soaring Society (BFSS) now has five members with the MRX PCAS. Mine is doing exactly what it is supposed to do: detect transponder or TCAS equipped aircraft being interrogated near my glider. two common things interrogate: a ground-based radar or airborne TCAS. It is also portable so we can take it with us when we teach or do intro rides in other planes. There are two modes: advisory and alert. Advisory is a two-beep warning that something is nearby and within my preset altitude and distance criteria. Alert is a four-beep sound that means the traffic is even closer. I have been operating my PCAS with the screen at its lowest brightness because it really is not important to me to know about traffic that is relatively far from me. All I need is the noise: two-beeps or four; that is, near or nearer. That noise says it all since the criteria for activating those sounds are set by the pilot, me. When MRX beeps, my eyes sweeps (added the extra "s" to complete the rhyme). In the nine months I've owned the MRX, there have been four cases of four-beeping. In all four cases, the traffic came from behind. And, in all four cases I had plenty of time to search and locate the traffic. The surprise traffic came from behind because MRX trained me to be better at spotting traffic ahead and to my sides. When I get rich, I'll also add a transponder. But for now, and recognizing that jet guys are flying heads-down more often than even they realize, PCAS is helping me a bunch. Oh, for a living I fly large jets equipped with TCAS. I watch my fellow crewmembers and they don't look out the window as often as they should. So, I'd rather know that I can see most of them, then to hope that they see me, and to hope that the Bonanza guys are talking to a radar controller who will alert them to my presence. Raul Boerner LS6-B "DM" |
On Jun 4, 11:24 am, Thomas Borchert
wrote: Andrew, Do they work when there is no radar facility nearby, or you are below the radar altitude? Your targets must be hit by radar (or an active TCAS from an airliner), not yourself. If that doesn't happen, the units don't work. How much traffic will there be in such areas? Since mid-air collisions occur near traffic patterns at low altitudes this is where I would want the system to be most responsive. It seems as if the opposite is true. Identifiying airplanes at cruise altitudes might make someone feel better, but they are rarely a hazard. It would be nice if there were a passive system that does not rely on a transponder, like a laser radar. |
On Jun 4, 7:31 pm, Andrew Sarangan wrote:
On Jun 4, 11:24 am, Thomas Borchert wrote: Andrew, Do they work when there is no radar facility nearby, or you are below the radar altitude? Your targets must be hit by radar (or an active TCAS from an airliner), not yourself. If that doesn't happen, the units don't work. How much traffic will there be in such areas? Since mid-air collisions occur near traffic patterns at low altitudes this is where I would want the system to be most responsive. It seems as if the opposite is true. Identifiying airplanes at cruise altitudes might make someone feel better, but they are rarely a hazard. It would be nice if there were a passive system that does not rely on a transponder, like a laser radar. We don't need to dream about exotic technology, the stuff available today does the job well enough to be very useful. Wherever you are flying you are very likely to be being painted by TCAS, civil SSR radar or military radar or TCAD (i.e. "TCAS lite" systems now being sold for GA aircraft, not many of these flying yet but it seems quite a lot of the $400k or so popular GA aircraft get sold with these systems). I see my transponder being interrogated and my MRX PCAS working out in the boondocks of the CA/NV great basin, down in valleys in central CA well away from SSR radar etc. where likely interrogation sources are airline traffic TCAS. This topic keeps coming up again and again, and unfortunately r.a.s seem to be write only, a search of the archives will turn up lots of dicusssion on PCAS. The bottom line is that PCAS works suprisingly. But it relies on transponder equipped aircraft so obviously won't work between gliders that are not transponder equipped. The issue here is getting your flying buddies to install tranponders not worrying about wether those tranponders are likely to be painted by radar or TCAS, etc. they very likely will. Zaon Flight systems keeps trying to educate people about this, look at the coverage maps at http://www.zaonflight.com/content/view/22/10/ as a starting point. The adoption pattern that I've seen for PCAS is one pilot at a glider port buys one and once people see that it works all of a sudden lots of pilots have them. I'm not suprised people are pessimistic that these little toys work, but they do work remarkably well, try to find somebody in your area who has one and get their feedback on it or even better borrow it and go flying. PCAS *is* capable of working at low altitudes including in remote areas, however I might disagree that the major danger of mid-air collisions are at "low altitudes". Certainly not the glider-heavy iron collisions that I am concerned about as a strategic threat to our sport. And we could argue about what low altitude means, but around places like Reno, or San Jose airspace where I fly the real danger points for collisions that I worry about are some victor airways and associated traffic into and out of VORs and approach/departure routes or heavy iron, particuary that traffic transitioning down from class A airspace and very very busy in the cockpit and certainly not expecting a glider sitting there just below class A... just like the Minden area Hawker/ASG-29 collision. BTW Transponders, keep coming up as well on r.a.s, they also work remarkably well - just ask anybody who flies with a transpoder near these areas and actually listens to or talks to approach control. Modern transponders don't have a high drain/exotic battery requirements (some PDAs/GPSs can be worse), might take a little work to install, there are really not difficult problems with antenna location etc. etc. Yes they cost money to buy and install and that can be a serious barrier -- everything else is addressable or just an excuse. Once you fly with a transponder in high traffic areas (like near Reno as JJ said) you suddenly wake up to ATC vectoring heavy iron around you, being seen by TCAS, etc. a whole scary world many people are oblivious to. If your shooting patterns miles from anywhere I don't care if you have a transponder, but if you are flying around, under or over major airspace then you are taking more of a risk and I get very worried about the damage to our sport when a glider collides with a commercial aircraft. (yep my main concern is about protecting the sport not protecting glider pilots from an individual mid-air, that's secondary - and on average we are probably more of a danager to ourselves through stall/spin accidents or lack of pre-flight/positive control checks than mid-air collisions.). Darryl Ramm 6DX |
Andrew,
Since mid-air collisions occur near traffic patterns at low altitudes this is where I would want the system to be most responsive. It seems as if the opposite is true. Two points: 1. Except at very remote fields, the likelyhood of airliners with TCAS being above the pattern is high at most busy GA fields, since they will be near major cities. 2. In a busy pattern, I would not want you to look at a fancy display giving you traffic information, I want you to look out. To expand: My experience with these simpler devices is that if you have more than, say, two close-by targets (a typical situation in a busy pattern), they become useless since you'll be busy looking outside. I turn our voice alerting off on the Monroy in these cases, since it will just say "traffic nearby" all the time and show a distance of a mile. I know that already, so I look outside. These units are great for alerting you at times where you don't expect traffic to be around, e.g. at that lonely field where it finds you that one other plane in the pattern you have missed, or during cruise when you are busy programming the GPS. -- Thomas Borchert (EDDH) |
I find it also effective in alerting for glider traffic nearby, if the
glider is transponder equiped and the transponder is on. Now that more pilots are flying with PCAS it is even more important to keep your transponder on in remote areas such as the White Mountains. Transponders are still interogated in these areas and will alert PCAS equiped gliders to your presence. Ramy On Jun 4, 9:38 pm, " wrote: On Jun 4, 7:31 pm, Andrew Sarangan wrote: On Jun 4, 11:24 am, Thomas Borchert wrote: Andrew, Do they work when there is no radar facility nearby, or you are below the radar altitude? Your targets must be hit by radar (or an active TCAS from an airliner), not yourself. If that doesn't happen, the units don't work. How much traffic will there be in such areas? Since mid-air collisions occur near traffic patterns at low altitudes this is where I would want the system to be most responsive. It seems as if the opposite is true. Identifiying airplanes at cruise altitudes might make someone feel better, but they are rarely a hazard. It would be nice if there were a passive system that does not rely on a transponder, like a laser radar. We don't need to dream about exotic technology, the stuff available today does the job well enough to be very useful. Wherever you are flying you are very likely to be being painted by TCAS, civil SSR radar or military radar or TCAD (i.e. "TCAS lite" systems now being sold for GA aircraft, not many of these flying yet but it seems quite a lot of the $400k or so popular GA aircraft get sold with these systems). I see my transponder being interrogated and my MRX PCAS working out in the boondocks of the CA/NV great basin, down in valleys in central CA well away from SSR radar etc. where likely interrogation sources are airline traffic TCAS. This topic keeps coming up again and again, and unfortunately r.a.s seem to be write only, a search of the archives will turn up lots of dicusssion on PCAS. The bottom line is that PCAS works suprisingly. But it relies on transponder equipped aircraft so obviously won't work between gliders that are not transponder equipped. The issue here is getting your flying buddies to install tranponders not worrying about wether those tranponders are likely to be painted by radar or TCAS, etc. they very likely will. Zaon Flight systems keeps trying to educate people about this, look at the coverage maps athttp://www.zaonflight.com/content/view/22/10/as a starting point. The adoption pattern that I've seen for PCAS is one pilot at a glider port buys one and once people see that it works all of a sudden lots of pilots have them. I'm not suprised people are pessimistic that these little toys work, but they do work remarkably well, try to find somebody in your area who has one and get their feedback on it or even better borrow it and go flying. PCAS *is* capable of working at low altitudes including in remote areas, however I might disagree that the major danger of mid-air collisions are at "low altitudes". Certainly not the glider-heavy iron collisions that I am concerned about as a strategic threat to our sport. And we could argue about what low altitude means, but around places like Reno, or San Jose airspace where I fly the real danger points for collisions that I worry about are some victor airways and associated traffic into and out of VORs and approach/departure routes or heavy iron, particuary that traffic transitioning down from class A airspace and very very busy in the cockpit and certainly not expecting a glider sitting there just below class A... just like the Minden area Hawker/ASG-29 collision. BTW Transponders, keep coming up as well on r.a.s, they also work remarkably well - just ask anybody who flies with a transpoder near these areas and actually listens to or talks to approach control. Modern transponders don't have a high drain/exotic battery requirements (some PDAs/GPSs can be worse), might take a little work to install, there are really not difficult problems with antenna location etc. etc. Yes they cost money to buy and install and that can be a serious barrier -- everything else is addressable or just an excuse. Once you fly with a transponder in high traffic areas (like near Reno as JJ said) you suddenly wake up to ATC vectoring heavy iron around you, being seen by TCAS, etc. a whole scary world many people are oblivious to. If your shooting patterns miles from anywhere I don't care if you have a transponder, but if you are flying around, under or over major airspace then you are taking more of a risk and I get very worried about the damage to our sport when a glider collides with a commercial aircraft. (yep my main concern is about protecting the sport not protecting glider pilots from an individual mid-air, that's secondary - and on average we are probably more of a danager to ourselves through stall/spin accidents or lack of pre-flight/positive control checks than mid-air collisions.). Darryl Ramm 6DX- Hide quoted text - - Show quoted text - |
| Thread Tools | |
| Display Modes | |
| PCAS - Portable Collision Avoidance System | [email protected] | Soaring | 13 | October 14th 06 08:21 PM |
| Collision Avoidance and ATC | Bubba | Soaring | 5 | September 1st 06 05:31 AM |
| Collision Avoidance Systems | [email protected] | Products | 0 | May 21st 06 11:15 PM |
| Collision avoidance equipment | samcapt | Products | 2 | May 13th 05 05:41 PM |
| Collision avoidance device | Jim Hendrix | Soaring | 1 | October 19th 04 10:24 AM |
