Any pireps for PCAS MRX collision avoidance system?
Old June 1st 07, 07:26 AM posted to rec.aviation.piloting
Mutts
Default Any pireps for PCAS MRX collision avoidance system?
worth 500 clams?..............
http://www.zaonflight.com/content/view/2/13/
Old June 1st 07, 05:15 PM posted to rec.aviation.piloting
Nathan Young
No comment on the Zaonflight PCASs, as I have no experience with
them...
I have flown a Ryan 9900B TCAD equipped Seneca, and found the bearing
display a critical part of the TCAD package. Occasionally the Ryan
would only show altitude/distance (no bearing), and it was pretty
frustrating to only know there is a guy out there... It is REALLY
hard to find a plane only by knowing approximate range and altitude
delta. This is especially the case when near the pattern, and there
are multiple targets.
If I was going to buy a Zaonflight, I would shell out the bigger bucks
for the one equipped with Bearing.
-Nathan
Old June 1st 07, 06:14 PM posted to rec.aviation.piloting
Chris G.
A friend of mine has a similar unit as this one (diff mfr) and I used it
on a flight. It annoyed me to no end because of the fact there was no
bearing information, just altitude and range.. BFD... I still have to
look everywhere for the darn traffic. Also, it's quite annoying on the
ground.
Chris G.
them...
-Nathan
Old June 2nd 07, 01:18 AM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Mutts" wrote in message
Ax over on r.a.soaring - they seem to be more popular over there.
Geoff
Old June 3rd 07, 09:25 AM posted to rec.aviation.piloting
Thomas Borchert
Nathan,
We have a non-bearing unit in our plane. No issue at all. Just look
outside when the alert comes and you'll find the target.
Thomas Borchert (EDDH)
Old June 3rd 07, 08:34 PM posted to rec.aviation.piloting,rec.aviation.soaring
Mutts
Crossposting over to soaring...
Some have commented that the lack of bearing info is a limitation,
others not so much.
Anyone with lots of experience using this unit or similar, thoughts?
Thanks!
On Fri, 1 Jun 2007 19:18:47 -0400, "Capt. Geoffrey Thorpe" The Sea
Old June 3rd 07, 10:41 PM posted to rec.aviation.piloting,rec.aviation.soaring
Andrew Sarangan
worth 500 clams?..............http://www.zaonflight.com/content/view/2/13/
others not so much.
Thanks!
Ax over on r.a.soaring - they seem to be more popular over there.- Hide quoted text -
- Show quoted text -
I have never flown with a TCAS, but I would think that relative
altitude and range should be enough help you see and avoid. But I do
have a question about these units. Do they work when there is no radar
facility nearby, or you are below the radar altitude?
Old June 3rd 07, 11:29 PM posted to rec.aviation.piloting,rec.aviation.soaring
5Z
The unit is passive, so relies on the other aircraft's transponder to
be replying to an interrogation. In Colorado, fairly low over the
mountains, one will be below radar coverage, so a VFR airplane with
transponder will not be interrogated, snd so will not be seen by the
MRX.
I have a few flights now with one of these and find that it does what
it's supposed to do. And that is give me a "heads up" when there is a
transponder nearby. At a glider contest, it will be constantly
reporting the towplanes as they drop off gliders nearby. Near a busy
GA airport, it will likely be the same. It will identify and tell you
about each new target within a few miles, so will reinforce your scan.
It's not a panacea, but just another tool to help me avoid getting run
down by a transponder equipped aircraft that may be flying "heads
down".
-Tom
Old June 4th 07, 12:29 AM posted to rec.aviation.piloting,rec.aviation.soaring
JJ Sinclair
A couple of week ago I heard; Glider-Glider-Glider, this is twin umpt-
upm, descending through 20,000 over the Pinenuts for landing at Carson
City.I responded that glider Jay Jay was descending through 10,000 on
the west side of the Pinenuts. About 3 minutes later the twin said,
Jay Jay, I have you on my TCAS and just got a visual on you about 500
feet below and 1 mile east of me. I responded, Roger that, I have you
on my PCAS and just got a visual on you also. We both agreed that this
was the way its supposed to work.
JJ
others not so much.
Thanks!
Old June 4th 07, 02:59 AM posted to rec.aviation.piloting,rec.aviation.soaring
Bob Noel
In article om,
MRX.
The unit won't see other transponders, unless the other transponder is
interrogated by a TCAS-equipped aircraft.
Bob Noel
(goodness, please trim replies!!!)
PCAS - Portable Collision Avoidance System [email protected] Soaring 13 October 14th 06 08:21 PM
Collision Avoidance and ATC Bubba Soaring 5 September 1st 06 05:31 AM
Collision Avoidance Systems [email protected] Products 0 May 21st 06 11:15 PM
Collision avoidance equipment samcapt Products 2 May 13th 05 05:41 PM
Collision avoidance device Jim Hendrix Soaring 1 October 19th 04 10:24 AM
