Backwash Causes Lift?
Old October 9th 07, 06:40 PM posted to rec.aviation.piloting
Mxsmanic
Default OK, IF Backwash Causes Lift then...
writes:
Nope. The lift/drag vectors are different as the AOA
changes.
Powered aircraft are gliders when the engines are off.
  #323
Old October 9th 07, 08:00 PM posted to rec.aviation.piloting
Phil
Default Backwash Causes Lift?
Le Chaud Lapin wrote:
If you
don't like the concept that the top of the wing is being sucked upward
by that lower pressure
It is not a matter of whether I like it or not. It is something that
simply does not happen. There is no sucking force.
then think of it this way. Imagine a cross-
section of the wing. The top surface of the wing forms a line. The
air just above this line has lower pressure. The air below this line
(inside the wing) has normal pressure.
So the air below the line is
pressing upward against it with more force than the air above is
pressing down.
I think you mis-understood me here. When I say the air below the line
is pressing upward, I am not referring to the air pressing upward on
the bottom of the wing. I am referring to the air _inside_ the wing
pressing upward on the underside of the top surface of the wing. The
air above the wing top surface has lower than normal pressure. The
air inside the wing has normal pressure. So it presses upward on the
top surface of the wing. This is lift generated by the top surface of
the wing.
Phil
  #324
Old October 9th 07, 08:03 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Phil wrote in news:1191952801.357185.176540
@r29g2000hsg.googlegroups.com:
If you
pressing down.
the wing.
What if your wing doesn't have any air in it?
Bertie
  #325
Old October 9th 07, 08:30 PM posted to rec.aviation.piloting
Le Chaud Lapin
the wing.
Air _inside_ the wing. Hmm...please don't take this the wrong way, I
can assure I don't mean it as an insult, but what do you do for a
living and what is your technical bacground (math, physics, etc.) if
you don't mind my asking?
If air inside the wing pushes upward on the underside of the top of
the wing, it also pushes downward on the overside of the bottom of the
wing, thus nullifying any effect of the air inside the wing.
-Le Chaud Lapin-
  #326
Old October 9th 07, 08:32 PM posted to rec.aviation.piloting
Le Chaud Lapin wrote in
oups.com:
the wing.
Wow, you're like, the next einstien, dude.
Bertie
  #329
Old October 9th 07, 09:35 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Bertie the Bunyip wrote:
Dudley Henriques wrote in
Mxsmanic wrote in
writes:
changes.
WEll, your engine has been off for some time and you're not a glider.
Bertie
Well......I guess ole' Mx could perform an experiment that proves his
point here.
If what he says has merit (God help us :-) that big ole 747 up there
with all 4 shut down should actually be able to CLIMB in those l'll ole'
thermals right over there now shouldn't it
God I hope he starts on gliders.
I got as thousand nopes in my pocket waiting.
Bertie
Some of the stuff he posts would simply be hilarious were it not for
those taking him on in vain attempts to straighten him out. The threads
involving all these elaborate counter explanations to the drivel he
posts just amaze me.
You're right; "nope" is absolutely the way to go with him and those like
him.
I've been watching some of these folks who are right on in the physics
department taking on this hot rabbit character on the lift issue.
Why the living hell anyone in their right mind would take the time to
deal with this from a serious standpoint is beyond my level of
comprehension. I've never seen so much utter bull**** in my life on a
serious flying forum.
The complete information about lift including all the corrections for
the misuse of Bernoulli in some of the texts are so readily available a
5 year old child could both find and understand them. Yet it goes
on....and on......and on!
Anyway, it's entertaining if nothing else!
Yup.........definitely....."Nope" is the way to go.
Dudley Henriques
  #330
Old October 9th 07, 09:43 PM posted to rec.aviation.piloting
Mxsmanic wrote in
writes:
changes.
glider.
Bertie
his point here.
ole' thermals right over there now shouldn't it
Bertie
threads involving all these elaborate counter explanations to the
drivel he posts just amaze me.
like him.
to
a 5 year old child could both find and understand them. Yet it goes
Zactly Why waste your breath telling them?
OTOH if he wants to pay me for my time...
Bertie
How much lift do you need? Dan Luke Piloting 3 April 16th 07 03:46 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 08:20 AM
what the heck is lift? buttman Piloting 72 September 17th 05 12:50 AM
Lift Query Avril Poisson General Aviation 8 April 21st 05 08:50 PM
thermal lift ekantian Soaring 0 October 5th 04 03:55 PM
