The future of displays in the cockpit?
Old December 22nd 09, 03:47 PM posted to rec.aviation.soaring
Tim Taylor
Default The future of displays in the cockpit?
Pixel Qi display with both e-text and color display modes.
http://www.pixelqi.com/products
http://techland.com/2009/05/30/pixel...-of-e-reading/
Old December 22nd 09, 08:00 PM posted to rec.aviation.soaring
Richard[_9_]
http://techland.com/2009/05/30/pixel...-is-the-future...
Tim,
The Pixel Qi screen is OK in the sun notice they did not show any
true colors in the picture. If you want to see the best in the sun.
http://www.hvgc.com.au/blog/?p=262
It is designed for sunlight readabiltiy.
I have not seen anything better, and I have looked.
Richard
www.craggyaero.com
Old December 22nd 09, 08:49 PM posted to rec.aviation.soaring
Tim Taylor
Tim,
The *Pixel Qi screen is OK in the sun notice they did not show any
true colors in the picture. * *If you want to see the best in the sun..
Richardwww.craggyaero.com
I don't need color and the reduced energy use would be extremely
helpful in the glider. I look forward to this technology being tried
for use in the glider. I don't see any data on the refresh rates in
the e-paper mode, that will be the determining factor if one can be
used in the glider.
Old December 22nd 09, 09:38 PM posted to rec.aviation.soaring
Richard[_9_]
http://techland.com/2009/05/30/pixel...-is-the-future....
Tim,
helpful in the glider. *I look forward to this technology being tried
for use in the glider. *I don't see any data on the refresh rates in
used in the glider.- Hide quoted text -
- Show quoted text -
Tim,
I fly with two batteries one 9 amp hour, one 12 amp hour, with the
following equipment I don't have battery issues with 7 hour flights.
Equipment CAI 302, 303, Ultimate full brightness max current draw,
Microair 760, Microair T2000 transponder, Borgelt B400, Tail water
dump solenoid (this draws the most when used).
Richard
www.craggyaero.com
Old December 22nd 09, 09:45 PM posted to rec.aviation.soaring
Richard[_9_]
Tim,
Tim,
I suspect that it would be rather hard to find a black and white
display, and I would guess that they don't use any less power.
If you don't want color you could probably turn it off with SeeYou
Mobile software.
Richard
www.craggyaero.com
Old December 23rd 09, 12:04 AM posted to rec.aviation.soaring
Darryl Ramm
Tim,
Tim,
If you don't want color you could probably *turn it off with SeeYou
Mobile software.
Richard
You need to read the link Tim posted.
I've mentioned Pixel Qi here before as a future interesting display
technology. Pixel Qi has a reflective LCD monochrome display with some
"color hinting" in full daylight that runs with full color and
backlight indoors. It is likely the most interesting near term
evolution in consumer display technology and should appear in
netbooks, e-book readers, tablets, etc. It's a pretty simple
transition for vendors using current LCD displays to adopt the Pixel
Qi display. They have high pixel density, low power (compared to
conventional LCD).Unliek e-ink you get full motion and video etc. But
it consumes significantly more power than e-ink. But personally I
think e-ink type displays are too limiting even for e-book readers.
Longer term we've got OLED, DMD and color e-ink technologies coming,
but they have their own problems and will take longer to arrive in
strength.
Darryl
Old December 23rd 09, 02:35 AM posted to rec.aviation.soaring
bildan
Tim,
Tim,
Mobile software.
Richard
strength.
Darryl
Actually, there are prototype full-color "electronic-ink" displays
being shown around to product developers. The press releases say they
are fast enough for video.
I expect that within a year or so we'll have paper thin reflective-
only extremely low power displays that look like magazine covers.
Glider cockpits will never be the same.
Digital Paper displays Roger Worden Soaring 11 December 11th 06 04:47 PM
Cockpit video displays. Was: Get Rid Of Warbirds At Oshkosh Jim Logajan Home Built 18 August 16th 06 06:10 AM
Cockpit video displays. Was: Get Rid Of Warbirds At Oshkosh Jim Logajan Piloting 16 August 16th 06 04:01 AM
IL2 Forgotten Battles Displays upside down LeonardR Simulators 15 June 4th 05 09:55 PM
More on FOTI / A-6 Radar Displays Mike Kanze Naval Aviation 0 September 28th 04 03:42 AM
