Cockpit video displays. Was: Get Rid Of Warbirds At Oshkosh
Old August 12th 06, 08:53 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Jim Logajan
Default Cockpit video displays. Was: Get Rid Of Warbirds At Oshkosh
Orval Fairbairn wrote:
Mark Hickey wrote:
Ernest Christley wrote:
A flag on the part of the protagonist moves the responsibility from
the antagonist seeing to the protagonist being seen (any time you
move your vehicle, you're the antagonist, the mover, the doer, the
responsible party). If the Avenger's co-pilot couldn't ride or walk
a wing to the run-up area, stick a bug-eye mirror on a stick or out
on a wing (temporarily). The solutions are simple, abundant, and in
use all around us every day.
With the price and availability of tiny little video cameras and LCD
displays, I can't imagine why anyone who could afford to fly a
warbird couldn't afford to put a forward-looking video system in
place (even if it's only a temporary installtion used for crowded
events). It would cost what - $100? - to prevent blind taxiing.
Mark Hickey
This "solution" requires too much "head buried in the cockpit" to be
practical.
Dudley Henriques made the same objection when I suggested the same idea on
rec.aviation.piloting. The most significant problem with the objection is
that no one is proposing that the pilot stare at the screen - simply add an
occasional glance at the screen to the pilot's normal visual scan. Such a
device should be no more objectional than the rearview mirrors in an
automobile - devices that add more to safe driving than they detract.
If the pilot is looking at the screen, he is not paying
attention to other things of equal or greater importance happening
around him.
I like the idea of spotters better.
This solution requires too much "staring at the spotter" to be practical.
Old August 12th 06, 09:31 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Jerry Springer
Mark Hickey
practical.
around him.
Plus it is really fun to leave the canopy cover on and taxi around the
airport. :-)
Old August 12th 06, 09:58 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Dudley Henriques[_1_]
"Jim Logajan" wrote in message
an
One more objection to the objection is :-)
At first glance, you might think that what you are proposing is safe and
workable, but it isn't in my opinion, and for several reasons. First of all,
nothing, and I repeat NOTHING, can take the place of a basic eyeball scan
OUTSIDE the cockpit when taxiing an aircraft in the WW2 tailwheel fighter
category. The entire concept of ground safety when taxiing these airplanes
is based on the simple premise that "if you can't clear or haven't cleared
the path in front of the nose for the linear distance the airplane will
travel before you can clear it again, YOU STOP THE AIRPLANE! This is a
cardinal rule when taxiing these airplanes and for very good reason. If you
hit something while taxiing a tailwheel prop fighter because you didn't see
it, you have taxied the airplane in conditions that are in direct violation
of this cardinal safety rule.
Now, as for your TV screen on the panel; it's no good for several reasons.
First of all, even if simply included in your taxi scan, it takes the scan
inside the cockpit then outside again which is bad, since a great deal of
the visual cues involved in taxiing these airplanes are based on a visual
cue received during a horizontal movement of the nose projecting a safe path
for a projected FUTURE TIME LINE, and not where the nose is pointed NOW!.
Secondly, any screen small enough to be placed in a fighter panel would not
be projecting an image in life size, and that alone brings an additional
mental calculation into the futures equation as to exactly how far ahead of
the airplane any viewed image in the screen might be.
Tools are wonderful, and in many instances that can be of great help, but
when it comes to taxiing a tailwheel fighter plane or a tailwheel torpedo
bomber, there is absolutely nothing that can replace the rule, "if you
haven't cleared it with your eyes, it hasn't been cleared"
Dudley Henriques
Old August 12th 06, 10:36 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Don Tuite
I agree that video's the wrong technology. Would an audible proximity
warning like they have for backing up big pickup trucks help?
Don.
On Sat, 12 Aug 2006 19:58:00 GMT, "Dudley Henriques"
an
Dudley Henriques
Old August 13th 06, 12:33 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Richard Riley" wrote in message
On Sat, 12 Aug 2006 20:36:36 GMT, Don Tuite
Sure. Just make sure that it's louder than an idling Merlin engine,
cause those are easy to miss.
There was a time when among my ground crew I was affectionately known as
"Captain WHAT."
(To my wife simply as "Baron Von Leftover :-)
If someone had forgotten to tell me something after I had fired up the
Mustang, they would climb up the side of the airplane, stand on wing and
lean in to the cockpit shouting whatever it was they wanted to tell me.
My answer invariably, even at idle, was to turn around, help them hold
whatever was in their hand and shout, "WHAT!!!"
Dudley Henriques
Old August 13th 06, 04:25 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Mark Hickey
an
snip
I suspect you're picturing the pilot staring continually at the video
screen while taxiing... that's not at all what I'd imagine.
Obviously most of your visual input is going to come from direct
observation "around the nose" of the aircraft - if someone's taxiing
in from the right, you want to see them before they're directly in
front of you. But if you're keeping your eyes open, there's no reason
to suspect that something's going to just appear in front of your
airplane unspotted - so there's no reason to spend a huge amount of
time fixated on the "straight ahead video view" - you'd use that like
you would a rear-view mirror. It sure beats stopping the airplane
every time you lose track of what might be directly ahead of you,
IMHO.
Mark Hickey
Old August 13th 06, 05:25 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Bob Moore
Doesn't sound as if Dudley has spent much time driving an automobile
with an in-dash GPS. :-)
Bob Moore
Old August 13th 06, 11:01 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Bob Moore" wrote in message
. 121...
Bob Moore
Nope, not much I'm afraid; but on the other hand, a bit more than a few
hours in tailwheel fighter planes if that counts for anything :-)
DH
Old August 14th 06, 12:12 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Mark Hickey
.121...
Heh heh heh... if you want to see what's (unadvisedly...) possible,
watch the morons driving down busy highways watching dashboard-mounted
video screens, texting with their cell phone, or my personal favorite,
reading. Makes taxiing a warbird seem safe in comparison. ;-)
Mark Hickey
Old August 14th 06, 12:20 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Peter Dohm
"Dudley Henriques" wrote in message
k.net...
. 121...
Bob Moore
DH
Being something of a tech guy, I'm a long time fan of cocpit video displays
for some purposes. I've even come around to the idea that they may be good
for some of the promary instruments--for instance there's a lot of really
informative stuff to overlay with an HSI...
However, Dudley has me convinced on this one. Swinging the nose from side
to side and watching outside is most probably the only way, unless all
traces of authenticity are abandonned and the panel is completely
modernized.
At the risk of seeming callous, this appears to be a really uncommon type of
accident and we really could take the position that "stuff happens." It is
a really scary way to meet one's demise; but everyone will be alert to the
hazard for several years, and, even if we do nothing at all, there will not
be a wave of similar accidents.
OTOH, It could be usefull to know who's on your six, andCessna 150s had rear
view mirrors as do most modern fighters. Pictures I've seen of WWII
fighters suggest that a lot of P51Ds and P38s may have had them in service
as well. The 150s had the mirror at glareshield level, while the fighters
all had/have their mirrors mounted as high as practical.
Peter
Sweltering in four layers of Nomex :-)
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Oshkosh Reflections Jay Honeck Home Built 54 August 16th 05 10:24 PM
Oshkosh Reflections Jay Honeck Owning 44 August 7th 05 03:31 PM
Oshkosh EAA Warbirds ??? Paul Restoration 0 July 11th 04 05:17 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
