Fed: Planes flying in "commercial" airspace must get GPS
Old May 29th 10, 08:13 PM posted to rec.aviation.piloting
VOR-DME[_3_]
Default Fed: Planes flying in "commercial" airspace must get GPS
says...
That is one of my concerns also.
I’m sure the FAA is relieved to know that you’re on the case, but if you
believe someone with your limited understanding of the system is going to
dream up failure modes that the NextGen developers, in their haste, have not
worked out to the tenth decimal place then you really have a leaky roof, and
probably a crack in the toilet bowl as well.
As far as the VOR’s are concerned, you’re barking up the wrong tree. ADS-B OUT
is the first mandated item, but far from the last. ADS-B IN will follow
shortly, CPLDC datalink and UAT transceivers as well. At this point we are one
ARINC fiber cable away from full ground-based control of every airplane in the
system (not that this is a stated goal, but to demonstrate that we are soon
achieving far better system integration than your 1980’s instrument textbook
lets on). So the VOR’s are really superfluous with a few exceptions, which
will be retained along with the odd NDB. It will be important to maintain a
minimum structure of surveillance radar as a backup, but then even though I
know the system ten times better than you do I would not be so presumptuous as
to imagine I have something to tell them about implementation.
Where the battle lines will be drawn is over the issue of cost per
participating aircraft and equipment mandates that the AOPA is likely to see
as overkill and overpriced for GA.
Old May 29th 10, 09:34 PM posted to rec.aviation.piloting
Mxsmanic
VOR-DME writes:
Heady stuff! Looks like the FAA and the NextGen developers better start
spending more time with USA Today, so they can be up to speed on all this
stuff they never even tought of!
USA Today is not the source of this information. And the FAA (or at least the
NextGen groupies at the FAA) won't care until someone dies. After all, they
look the other way when airlines violate regulations.
Old May 29th 10, 09:39 PM posted to rec.aviation.piloting
Mxsmanic
writes:
You have no clue what the jamming susceptibility of modern GPS is or what
features exist (current and planned) to thwart it.
Actually I do, as I've been following GPS since long before the average person
became aware of its existence. I'm afraid jamming is a serious potential
problem, for a number of reasons related directly to the technology of GPS and
to satellite communications in general. Spoofing is a serious issue, too,
which is why the DoD started encrypting its P code years ago. Unfortunately,
encryption is not a realistic option for civil aviation users, because of the
logistics of key distribution, and because it would make the signal unusable
to other user communities.
In reality, jamming effects a small area and is a real concern only to the
military which would expect jamming in the area of enemy targets.
Anyone can jam a GPS signal, and a small area is more than sufficient--if it
happens to be centered on New York City, for example. Spoofing requires more
sophistication, but hardly anything unattainable for bad guys.
A solar flare large enough to "knock them all out at once" would also take
out a lot of other stuff making the lack of GPS a minor issue.
If GPS is the only navigation option, it's a major issue even if other systems
are affected as well. VORs, at least, would still be available.
Old May 29th 10, 09:41 PM posted to rec.aviation.piloting
Mxsmanic
VOR-DME writes:
I’m sure the FAA is relieved to know that you’re on the case ...
The FAA has its head firmly buried in the sand.
What takes over when GPS fails? Loran is gone. NDBs and VORs supposedly will
be gone. What's left? A magnetic compass?
It will be important to maintain a minimum structure of surveillance radar
as a backup ...
Radar should be permanently retained. It helps prevent spoofing, for example.
The FAA seems to be much more a friend of airlines than a friend of GA.
Old May 29th 10, 10:38 PM posted to rec.aviation.piloting
Mxsmanic
VOR-DME writes:
I just told you, and you didn't get it.
None of the things you mention provides navigation capabilities. The aircraft
and its crew still have to be able to determine where they are. They cannot do
that with datalinks or other gadgets unrelated to navigation. Even remote
ground control of aircraft would require some sort of on-board navigation
system, unless the system relied on theoretical calculations and dead
reckoning, which would be hopelessly inaccurate in practice.
Old May 29th 10, 11:07 PM posted to rec.aviation.piloting
george
On May 30, 8:38*am, Mxsmanic wrote:
VOR-DME writes:
Bloody hell but you're thick.
Didn't you read what he wrote and assimilate/understand the
information?
Old May 29th 10, 11:30 PM posted to rec.aviation.piloting
We are at MXMAX now - that's the threshold where MX cannot assimilate any more
information
Well VOR DME, you a better man then me going as far as you did.
He has no clue what the real world is out here. As I stated in my
first reply to him, why should he be concerned as he is not a user of
the system for navigation.
His reading comprehension seems be less then a 6 year old as I am not
familiar with the next generation stuff but you did an outstanding job
explaining it in user friendly terms for this pilot.
Old May 30th 10, 12:20 AM posted to rec.aviation.piloting
Jim Logajan
VOR-DME writes:
airc
raft
cann
ot do
remote ground control of aircraft would require some sort of on-board
navigation system, unless the system relied on theoretical
calculations and dead reckoning, which would be hopelessly inaccurate
in practice.
information?
I read and assimilated the part where VOR-DME used the classical fallacy of
appeal to authority:
"... if you believe someone with your limited understanding of the system
is going to dream up failure modes that the NextGen developers, in their
haste, have not worked out to the tenth decimal place..."
It is an assertion of competence on the part of the FAA that also happens
to be historically inaccurate.
The only legitimate goal that the FAA can reasonably seek by its rules,
separation of commercial aircraft from all other airborne objects
(including birds), could also be accomplished by requiring on-board radar
and alert systems for those aircraft. This is a technical alternative to
ADS-B that accomplishes that goal. It also manages to equitably match the
burden with the benefit. It also permits non-commercial GA the freedom to
choose their level of risk versus cost.
The ADS-B out mandate doesn't accomplish either of the above.
(USA) US/Mexico "airspace" (boundary) files available Tuno Soaring 4 March 27th 10 08:17 PM
some planes [11 of 11] "old-air-planes-crashed-underwater-photos-pictures.jpg" yEnc (1/1) No Name Aviation Photos 0 August 9th 09 10:36 PM
On Sharing airspace with "non-rated UAV "pilots" vaughn Piloting 15 March 15th 09 05:08 PM
"Fly Baby, you violated Class B Airspace" Ron Wanttaja Piloting 27 September 5th 07 09:30 PM
Aviation Conspiracy: Connecticut To Get "Creamed" By Airspace Redesign Change? Free Speaker General Aviation 0 August 8th 06 03:42 PM
