See
http://www.usatoday.com/travel/fligh...rol28_ST_N.htm I assume by "commercial" airspace they mean areas like Class A-B or A-C. And by "GPS" they appear to mean not just GPS but ADS-B. The article doesn't say which private aircraft will be expected to install this equipment, but the deadline is 2020. I hope the government will not use this as an excuse to decommission VORs. VORs are the only back-up for a satellite system that is easily jammed or spoofed (unless you have an INS, but there aren't too many small single-engine aircraft so equipped). |
If your ‘aviation interest’ is insufficient to inspire you to monitor more
authoritative sources than USA Today, your reporting is condemned to be as spotty and non precise as theirs. The mandate just issued is for ADS-B OUT by 2020 in all aircraft operating in airspace where a transponder is required today. You may not know exactly what that means (and in fairness, many pilots may be rusty on this as well), but they will simply look it up, which is what you should do as well if you’re willing to go beyond USA Today. This requirement, by the way, is the first implementation mandate for the system you dismissed as fiction only a few days ago. As for VOR’s, the FAA NextGen roadmap clearly indicates a decommissioning of this system. They do not appear to share your concern that the satellite system is 'easily jammed' and they are unlikely to consult with you before decommissioning the VOR’s. In article , says... See http://www.usatoday.com/travel/fligh...rol28_ST_N.htm I assume by "commercial" airspace they mean areas like Class A-B or A-C. And by "GPS" they appear to mean not just GPS but ADS-B. The article doesn't say which private aircraft will be expected to install this equipment, but the deadline is 2020. I hope the government will not use this as an excuse to decommission VORs. VORs are the only back-up for a satellite system that is easily jammed or spoofed (unless you have an INS, but there aren't too many small single-engine aircraft so equipped). |
VOR-DME writes:
As for VOR’s, the FAA NextGen roadmap clearly indicates a decommissioning of this system. They do not appear to share your concern that the satellite system is 'easily jammed' and they are unlikely to consult with you before decommissioning the VOR’s. The FAA may come to regret their unwillingness to consider the security issues. It's odd that people are so willing to overlook security in their rush to adopt new technology, and then they claim that they never knew the risks when bad things start to happen. It's always Someone Else's fault. |
On May 29, 5:17*am, Mxsmanic wrote:
See http://www.usatoday.com/travel/fligh...rol28_ST_N.htm I assume by "commercial" airspace they mean areas like Class A-B or A-C. And by "GPS" they appear to mean not just GPS but ADS-B. The article doesn't say which private aircraft will be expected to install this equipment, but the deadline is 2020. I hope the government will not use this as an excuse to decommission VORs.. VORs are the only back-up for a satellite system that is easily jammed or spoofed (unless you have an INS, but there aren't too many small single-engine aircraft so equipped). I carry my waterproof, handheld Lowrance as a backup. Good for the boat or plane and works perfectly with independent battery. However, I haven't taken it underwater and hope not to. Decommissioning a redundancy system has to be weighed against the benefit/loss of doing so. --- Mark --- Mark |
On May 29, 4:17*am, Mxsmanic wrote:
I hope the government will not use this as an excuse to decommission VORs.. VORs are the only back-up for a satellite system that is easily jammed or spoofed (unless you have an INS, but there aren't too many small single-engine aircraft so equipped). Why do you care? It doesn't affect MSFS. BTW, you really demonstrate how clueless you are for real world flying. If the satellite system is jammed it's just not ONLY going to affect small engine airplanes. I use the very same satellites in my Garmin 430 and 296 as the airliners do. |
VOR-DME writes:
Heady stuff! Looks like the FAA and the NextGen developers better start spending more time with USA Today, so they can be up to speed on all this stuff they never even tought of! USA Today is not the source of this information. And the FAA (or at least the NextGen groupies at the FAA) won't care until someone dies. After all, they look the other way when airlines violate regulations. |
Mxsmanic wrote:
VOR-DME writes: Heady stuff! Looks like the FAA and the NextGen developers better start spending more time with USA Today, so they can be up to speed on all this stuff they never even tought of! USA Today is not the source of this information. And the FAA (or at least the NextGen groupies at the FAA) won't care until someone dies. After all, they look the other way when airlines violate regulations. Babbling, delusional nonsense. Airlines are fined for violating requlations quite often and there were several occurances this month alone. Of course, what do you expect from a person who gets aviation news from USA Today and aviation experience from MSFS? -- Jim Pennino Remove .spam.sux to reply. |
In fairness to MX I think he meant that in the event of GPS unavailability,
airliners would be able to resort to their INS navigators, which small planes do not have. I am not sure though that airliners will continue to be equipped with INS systems after NextGen implementation, and even if they are this is not good enough, as it cannot reliably provide better than RNP 1.0 and has no approach capability. Many were hoping that LORAN-C would be retained and even developed as a backup, but that was dashed recently when the system was definitively abandoned. VOR’s are costly to maintain, and the FAA wants to move away from them as quickly as possible (going back to my statement that Victor airways are obsolescent and pilots so equipped should be filing \G as much as possible already). It could be that the best backup for GPS will be other satellite-based structures, GONASS or soon to be GALILEO. In article , says... If the satellite system is jammed it's just not ONLY going to affect small engine airplanes. I use the very same satellites in my Garmin 430 and 296 as the airliners do. |
| Thread Tools | |
| Display Modes | |
| (USA) US/Mexico "airspace" (boundary) files available | Tuno | Soaring | 4 | March 27th 10 08:17 PM |
| some planes [11 of 11] "old-air-planes-crashed-underwater-photos-pictures.jpg" yEnc (1/1) | No Name | Aviation Photos | 0 | August 9th 09 10:36 PM |
| On Sharing airspace with "non-rated UAV "pilots" | vaughn | Piloting | 15 | March 15th 09 05:08 PM |
| "Fly Baby, you violated Class B Airspace" | Ron Wanttaja | Piloting | 27 | September 5th 07 09:30 PM |
| Aviation Conspiracy: Connecticut To Get "Creamed" By Airspace Redesign Change? | Free Speaker | General Aviation | 0 | August 8th 06 03:42 PM |
