Kestrel DG200 canopy mod.
Old November 19th 19, 09:02 PM posted to rec.aviation.soaring
Charlie Quebec
Default Kestrel DG200 canopy mod.
You seriously need to understand the max weight of the none lifting parts, you can’t use the weight available as water ballast in the wings in your calculations, as being in the wings it does not
increase the bending loads of the spar, and you will be overloading the lift pins on the fuselage. The suggestion to put extra weight in the wings by fitting extra ballast capacity is also a very dangerous concept as you will he increasing the negative g loads which are only half the positive g rating. The max weight is there for a reason.
Otherwise, it’s a good plan. Bringing the profile to accurate form is your best way to improve performance by far, as Slingsby did a very poor job of profile accuracy.
Kestrel 17 Polar Jim Archer Soaring 1 November 24th 08 05:33 PM
Kestrel 19 Questions [email protected] Soaring 13 October 30th 08 05:26 PM
Wanted. DG200 or DG 400 17M tips extensions. [email protected] Soaring 0 November 7th 07 06:39 AM
Epic vs Kestrel Kyle Boatright Home Built 0 August 3rd 06 04:19 AM
Slingsby Kestrel 19m Grant Johnson Soaring 1 July 27th 06 07:14 AM
