Jet-powered VTOL drone is like a quadcopter on steroids [1/4] - Jet-powered VTOL drone.jpg (1/1)
Old November 30th 19, 06:32 PM posted to alt.binaries.pictures.aviation
Miloch
Default Jet-powered VTOL drone is like a quadcopter on steroids [1/4] - Jet-powered VTOL drone.jpg (1/1)
https://newatlas.com/drones/ab5-jetq...powered-drone/
While propeller planes certainly do have their place, sometimes the extra speed
and thrust of a jet engine is what's really needed. Dallas, Texas-based
FusionFlight has applied that sort of thinking to quadcopter-style drones,
resulting in the AB5 JetQuad.
According to the company, the AB5 is "the world’s smallest and most powerful
jet-powered drone with vertical take-off and landing [VTOL] capabilities."
Instead of the usual four electric motors and propellers, the current prototype
has four diesel-powered microturbine jet engines which produce a combined 200
horsepower (149 kW) at full throttle. Thanks to a proprietary vectoring system
known as the H-Configuration, the thrust from these engines can be directed
either to move the drone vertically when taking off and landing, or horizontally
while in flight.
The production version of the aircraft will reportedly have a top speed of over
300 mph (483 km/h), with one fill of its 5-gallon (19-l) fuel tank being good
for 30 minutes of hovering or 15 minutes of cruising. Down the road, the
addition of components such as afterburners could boost its speed considerably.
It will carry a maximum payload of 40 lb (18 kg), with cargo being either
attached to the drone itself or dangled on a line underneath – the company
states that the cargo won't be blasted by the engines in the latter
configuration, as the thrust is never vectored straight below the AB5. The drone
itself weighs a claimed 50 lb (23 kg), with a full tank of fuel adding another
40 lb.
FusionFlight CEO Alexander Taits tells us that the AB5 may be on the market by
2021, priced somewhere between US$200,000 and $250,000 depending on the model.
Potential buyers are likely to be putting a premium on speed and power.
"The jet engines can put out significantly more power then electrically-driven
propellers and also allow the vehicle to travel at much higher speeds," says
Taits. "Diesel fuel, on a pound-for-pound basis, stores 40 times more energy
then any lithium-type battery and also will take minutes to refuel instead of
the hours it takes to recharge an electrical drone."
Click image for larger version
Name:	Jet-powered VTOL drone.jpg
Jet-powered VTOL drone is like a quadcopter on steroids [2/4] - Jet-powered VTOL drone 2.jpg (1/1) Miloch Aviation Photos 1 December 1st 19 04:59 AM
Jet-powered VTOL drone is like a quadcopter on steroids [3/4] - Jet-powered VTOL drone.png (1/1) Miloch Aviation Photos 0 November 30th 19 06:32 PM
People can now order over-the-counter medication and snacks to be delivered to their homes by DRONE... - A Wing delivery drone lowers a cord onto which the package is hooked and then lifted back up to the drone.jpg ... Miloch Aviation Photos 1 October 19th 19 11:39 AM
The US Army is making a laser-powered drone that can fly indefinitely Larry Dighera Piloting 0 September 4th 18 11:59 AM
Facebook's massive solar-powered drone takes its first flight Larry Dighera Piloting 1 July 25th 16 04:25 AM
