A6 Intruder----Question?
Old October 29th 03, 07:26 AM
Larry
snip but modified to try and eliminate the "chugs", . .
That brings back MANY memories- We spent LOTS of nights out there on the
high-power line trying to duplicate that chug. Watchin the trim box, blow
out the PT-2 line, watch those pressures, trying to concentrate while
FREEZIN our asses off!
We called it "jam accell"- creep the throttle up and SLAM it to military,
slam it back down, then repeat about 250 times. Nope, were not going to
"A799" this one!
The high-power line was WAY out there between the runways at Whidbey.
MidRats never tasted so good after spending a few hours out on high-power!
Cold, dark, wet. The "Rock" was one of those places you either loved, or
hated.
Lots of memories.
Thanks, I *almost* forgot about that. Those were pretty good times-
definitely worth revisiting.
Larry
AECS (AW/SW/MTS)
Disabled Combat Veteran
USN Retired
20 years of Navy in my rear view mirror
and getting further away every day ;-)
"user" wrote in message
Prowler Motors are mostly J52-408Bravo's now. Same thrust as the
408A's (10,400 - 11,200 lbs per motor) but modified to try and
eliminate the "chugs", (didn't work, the compressor still stalls under
the right conditions), also have new 3 1/2 bearings and a reinforced
or beefed up compressor casing.
On Tue, 28 Oct 2003 07:27:07 -0500 (EST), (Kurt
{:{) wrote:
Hi,
I was to an air show awhile back. I was inspecting a Navy A6 Intruder. I
caught the exhaust end of the tail pipe and noticed a circumference of
mesh "feathers" on the inner ID, that honestly looked like dragonfly
wings, gossamer in texture. I wonder what the function of this is, what
the material is, and how is it produced? A stamping process is a guess.
Material---titanium?
Thanks.
Kurt
Old November 1st 03, 09:02 AM
user
Hey Larry,
I'm kinda new in here and just beginning to learn the ropes. Very cool
group! The chugs were a huge annoyance, and about 2 years ago, the
wing came up with a standard procedure for troubleshooting the
compressor stall problem. Of course you had to use the trim box and
the borescope. You can relate to this:. It was a typical Naval
Aviation Maintenance evolution to have my mechs walk up and down the
flight line on a cold friday night begging, borrowing and stealing a
working power supply from one squadron and a power cord from another
and a working optical lens from another etc.to piecemeal together a
good borescope. It was a real pain in the ass. And there were only 13
trim boxes for 15 squadrons, ours was loaned out to a deployed
squadron so we had to borrow that too. Im sure you'll agree; the chug
problems were a minor annoyance compared to the 3 1/2 bearing fiasco
that started 2 years ago! (by the way, the Rock is my home and I love
it there, going back to Prowlers next year after I finish my sentence
in the desert here in Cali)
On Tue, 28 Oct 2003 22:26:29 -0800, "Larry"
"A799" this one!
hated.
Lots of memories.
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 06:07 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 07:05 PM
