#51
Thank you for the responses. It appears as if the aircraft in question, is nowhere near flight worthy at this time. Just curious though, What's a typical Vref speed for landing ? (presuming all ordnance has been expended). And are these numbers something the pilot calculates himself, or is it given to him ? Can ACLS be considered helpful at all ? (similar to perhaps a Category III ILS auto land ?) Does any Hornet driver here actually trust it ? (and why would you even use it?). What is the crosswind technique alluded to below ? (in lieu of the forward sideslip)? "Doug "Woody" and Erin Beal" wrote in message ... There are a couple of "gotchas" in just flying the thing, but nothing a few flights wouldn't iron out. If you've never experienced flight gear, that would be a new treat (helmet, mask, torso harness, g-suit). Since the motors are way in the back (35 or so feet behind you), you'd have to get used to the "detached" sensation of flying the jet. There is no air noise or airframe feedback with regard to airspeed or engine power setting whatsoever. The airplane feels the same flying at 180 kts at 30000 feet as it does at 550 kts at 500 feet. A good instrument scan is a must. WRT landings, the HUD makes them pretty easy. On this Lot 6, you may find single chamber struts which means CV type landing is probably not a good idea (max trap for single chamber struts was 30,500 lbs vice the 33k UNR or 34K Restricted for the current F/A-18). Pretty simple stuff to flare a landing in the Hornet though. I have taken guests into the simulator, and the ones with some flight time do fairly well at getting it on the runway. The biggest landing obstacle would be encouraging you NOT using a forward slip as a crosswind correction--makes the airplane do the funky chicken on the runway. OBTW, no localizer, ILS, VOR. Either fly TACAN approaches or PAR in the weather (if you want a precision approach). --Woody |
#52
On 2/14/04 4:13 PM, in article , "Mr Smith"
wrote: Thank you for the responses. It appears as if the aircraft in question, is nowhere near flight worthy at this time. Just curious though, What's a typical Vref speed for landing ? (presuming all ordnance has been expended). And are these numbers something the pilot calculates himself, or is it given to him ? Roughly 125 knots. Can ACLS be considered helpful at all ? (similar to perhaps a Category III ILS auto land ?) Does any Hornet driver here actually trust it ? (and why would you even use it?). Nope. Lots of black boxes fighting to be sync-ed up with the ones on the carrier. Not many NAS's have the SPN-46/48 (whatever) that is required to conduct ACLS approaches at the field either. As I remember, Lemoore, Oceana, and Whidbey have them... Not sure about the rest. What is the crosswind technique alluded to below ? (in lieu of the forward sideslip)? Crab to land and kick out half the crab prior to touch down. --Woody "Doug "Woody" and Erin Beal" wrote in message ... There are a couple of "gotchas" in just flying the thing, but nothing a few flights wouldn't iron out. If you've never experienced flight gear, that would be a new treat (helmet, mask, torso harness, g-suit). Since the motors are way in the back (35 or so feet behind you), you'd have to get used to the "detached" sensation of flying the jet. There is no air noise or airframe feedback with regard to airspeed or engine power setting whatsoever. The airplane feels the same flying at 180 kts at 30000 feet as it does at 550 kts at 500 feet. A good instrument scan is a must. WRT landings, the HUD makes them pretty easy. On this Lot 6, you may find single chamber struts which means CV type landing is probably not a good idea (max trap for single chamber struts was 30,500 lbs vice the 33k UNR or 34K Restricted for the current F/A-18). Pretty simple stuff to flare a landing in the Hornet though. I have taken guests into the simulator, and the ones with some flight time do fairly well at getting it on the runway. The biggest landing obstacle would be encouraging you NOT using a forward slip as a crosswind correction--makes the airplane do the funky chicken on the runway. OBTW, no localizer, ILS, VOR. Either fly TACAN approaches or PAR in the weather (if you want a precision approach). --Woody |
#53
Mr Smith- What's a typical Vref speed for landing ? (presuming all
ordnance has been expended). And are these numbers something the pilot calculates himself, or is it given to him ? BRBR You check airspeed for landing vs the AOA but you use 'onspeed AOA', where airspeed varies with weight, for landings, always the same AOA..15 units for the F-4. smith Can ACLS be considered helpful at all ? (similar to perhaps a Category III ILS auto land ?) Does any Hornet driver here actually trust it ? (and why would you even use it?). BRBR In the F-4 and Turkey, I have had Mode 1s to touchdown( I know a contradiction, Mode 1s are always to touchdown) but they were an emergency procedure. I doubt any modern aviator relies on this system. P. C. Chisholm CDR, USN(ret.) Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer |
#54
contradiction,Mode 1s are always to touchdown) but they were an emergency procedure. I doubtany modern aviator relies on this system I could never get auto throttles to work right in the A-6 in the Prowler they were a little better. I tried to do a coupled approach on Sara (90-91) and ended up with a bolter. The Hornets were doing them all the time they seemed to have the system and ship tweeked up really well. I think it was mandentory for the first Hornet down the chute to attempt a Mode 1 as I recall they flew a lot of them maybe 25% were hooked up. Sparky |
#55
I know A6 power control was problematic from development through fleet
introduction in 1969. The feedback loop with the ASN-54 APC was inconsistent, and the kinesthetics were unacceptable to the pilot when the system introduced purposeful glide slope deviations for self-check monitoring purposes. The RANGER/CVW-2 deployment in 1969 was the first in which all aircraft aboard, including the C1A COD and the SH-3's were ACLS-equipped. Mode 1 was not authorized at that time for any aircraft. The idea was to "get 'em home safely on a dark and stormy night". Do Hornets have yaw strings glued to the radome like F-4's did? Rick "Elmshoot" wrote in message ... In the F-4 and Turkey, I have had Mode 1s to touchdown( I know a contradiction,Mode 1s are always to touchdown) but they were an emergency procedure. I doubtany modern aviator relies on this system I could never get auto throttles to work right in the A-6 in the Prowler they were a little better. I tried to do a coupled approach on Sara (90-91) and ended up with a bolter. The Hornets were doing them all the time they seemed to have the system and ship tweeked up really well. I think it was mandentory for the first Hornet down the chute to attempt a Mode 1 as I recall they flew a lot of them maybe 25% were hooked up. Sparky -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
#56
"Elmshoot" wrote...
I could never get auto throttles to work right in the A-6 in the Prowler they were a little better. I tried to do a coupled approach on Sara (90-91) and ended up with a bolter. The Hornets were doing them all the time they seemed to have the system and ship tweeked up really well. I think it was mandentory for the first Hornet down the chute to attempt a Mode 1 as I recall they flew a lot of them maybe 25% were hooked up. I had a total of 4 successful Mode 1 approaches in my career -- 2 each to Kitty Hawk and Nimitz. "It's always something; if it's not one thing, it's another..." (Roseanne Rosannadanna) Autothrottle excursions, Beacon failure, and autopilot excursions were the 3 predominant failure modes... |
#57
Four more than I. While the Turkey had an excellent APCS, I was never
exposed to the "certified" ACLS model. As for the Phantom, got just past tipover once ... then all hell broke loose. The F-8 was worthy of a chuckle. The J's were retrofitted with bullseye needles. To display CL and GS one had to flip a switch from "TACAN" to "ACLS" ... it reconfigured the ID-249 for the approach. A really good thing, but hardly ACLS. R / John |
#58
Rick,
I know A6 power control was problematic from development through fleet introduction in 1969. This was still the case when the Lizards (VA-95) went to sea in 1973 aboard CORAL MARU. We never flew any "coupled" passes closer in than 1/4 mile. -- Mike Kanze "Asking what a pilot thinks about the FAA is like asking a fireplug what it thinks about dogs." - from Bill "Windmill" Young "Yofuri" wrote in message ... I know A6 power control was problematic from development through fleet introduction in 1969. The feedback loop with the ASN-54 APC was inconsistent, and the kinesthetics were unacceptable to the pilot when the system introduced purposeful glide slope deviations for self-check monitoring purposes. The RANGER/CVW-2 deployment in 1969 was the first in which all aircraft aboard, including the C1A COD and the SH-3's were ACLS-equipped. Mode 1 was not authorized at that time for any aircraft. The idea was to "get 'em home safely on a dark and stormy night". Do Hornets have yaw strings glued to the radome like F-4's did? Rick "Elmshoot" wrote in message ... In the F-4 and Turkey, I have had Mode 1s to touchdown( I know a contradiction,Mode 1s are always to touchdown) but they were an emergency procedure. I doubtany modern aviator relies on this system I could never get auto throttles to work right in the A-6 in the Prowler they were a little better. I tried to do a coupled approach on Sara (90-91) and ended up with a bolter. The Hornets were doing them all the time they seemed to have the system and ship tweeked up really well. I think it was mandentory for the first Hornet down the chute to attempt a Mode 1 as I recall they flew a lot of them maybe 25% were hooked up. Sparky -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
#59
Spn-43(needles) and autothrottles, the way to go in VF-31, last cruise...a
'peek' is worth a thousand 'scans' tho... Forrestal started asking people to try Mode 1s..Sometimes worked, sometimes an automatic trip into the penalty box... P. C. Chisholm CDR, USN(ret.) Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer |
#60
dano- It seems to me that the A-4 might actually be a good candidate for
private ownership. It's relatively small and simple, mostly electrical, electromechanical and hydraulic I assume (not of the complexity of the 60s, 70s, 80s), single engine BRBR I think the only 'gotchas' would be slat rigging, which is certainly an art in itself. A poorly rigged slat could spell disaster. The other is the ejection seat in the 'E' model, which I would not ever sit in. Bug Roach's seat failed in the 'E' he was flying, the rocket motor failed and he hit the tail as he went out. A static test of 10 rocket motors in storage had 7 failures. I grounded my 'E' models and refused to fly them after that. Just wrapped them up, took them outta reporting and looked for ways to get them to D-M. P. C. Chisholm CDR, USN(ret.) Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer |
| Thread Tools | |
| Display Modes | |
| Blue Angels Show | ramrod48 | Military Aviation | 6 | September 7th 04 11:01 PM |
| Blue Angels star in air show | Otis Willie | Military Aviation | 9 | May 25th 04 06:41 PM |
| Once again-Threshold, The Blue Angels Experience | Pechs1 | Naval Aviation | 28 | February 8th 04 01:22 AM |
| Blue Angels Video - Is it a Fake? | Ken Morano | Military Aviation | 4 | November 18th 03 11:14 PM |
| Blue Angel's Gear Door Broken? | Clay N4AOX | Military Aviation | 15 | October 6th 03 09:01 AM |
