CSA Redux?
Old March 21st 04, 09:29 AM
sid
Default CSA Redux?
Looks like the need for more than single seat fighters is becoming an
issue again. From the April Seapower:
http://www.navyleague.org/sea_power/apr_04_16.php
"Boeing's Ted Herman, business development manager for the F-18
program, told Sea Power the Super Hornet tanker helps "extend the
legs" of the strike aircraft and does not compromise on aerodynamic
performance.
But the Navy is not entirely content with the Super Hornet as a
tanker. While converted to refuel, the jet is not carrying weapons for
strike missions. Fitzgerald said the Navy would consider a replacement
for its C-2 logistics aircraft that may offer refueling capability.
The C-2 replacement would either be the V-22 Osprey tiltrotor or the
next model C-2. The Navy begins to retire the current fleet of C-2s in
2014.
"We are thinking about whether we just have C-2 replacement planes for
logistics, or whether we should buy some more that would be available
for recovery refueling," Fitzgerald said."
Instead of a C-2ish aircraft, I would suggest a modern analogue to
what was arguably the most sucessful "CSA" the Navy produced:
http://www.a3skywarrior.com/featurep...Det1_NG616.jpg
And this "CSA" could carry up to 12,500 lbs of ordnance internally and
had an *unrefueled* combat range of better than a 1000nm. Fifty years
later there is gushing praise for 4000 lbs and 600 nm.
http://www.a3skywarrior.com/cogdell/drop.jpg
Old March 21st 04, 05:38 PM
damron
What a nice surprise, to jump on a newsgroup and see a plane my father
crewed in.
Old March 22nd 04, 12:22 AM
PPowondra
Subject: CSA Redux?
Date: 3/21/2004 3:29 Eastern
Why not? This time around we'll
put real ejection seats in it and
modern jet engines. The Navy
could even return to the ELINT
mission off the boat.
I'll have to ask the aviator types
what a 21st century Whale would
be equiped with.
Paul
Old March 22nd 04, 03:12 AM
Thomas Schoene
performance.
2014.
An A-3 size airframe would be handy for tanker duties. and could maybe also
serve as a carrier-based mini-MC2A (combined AWACS/ELINT aircraft).
Developing this would be relatively straightforward, assuming some money can
be found.
The problem comes when you try to make it a bomb dropper too. That demands
a lot of more expensive design choices to keep the aircraft survivable
against modern defenses (signature reduction, weapon delivery systems, etc.)
That's not going to be affordable at all.
Sure, a new A-3 could carry more bombs, but it woudn't strike more targets
at once, which two or three JSFs can do.
Tom Schoene Replace "invalid" with "net" to e-mail
"Our country, right or wrong. When right, to be kept right, when
wrong to be put right." - Senator Carl Schurz, 1872
Old March 22nd 04, 04:20 AM
Charlie Wolf
I've been gone for quite a while (retired AWC - 1992) but I still
don't fully understand why they are throwing away the S-3's?? Seems
it's the answer to several of the things that have been mentioned in
this thread...
Regards,
performance.
2014.
Old March 22nd 04, 04:50 AM
gizmo-goddard
"Charlie Wolf" wrote in message
this thread...
It would be. My best guess would be that the Hornet Mafia, wanting to use
the Hornet for anything and everything wouldn't allow NAVAIRSYSCOM to even
consider any other airframe.
__!_!__
Gizmo
"Welcome to NAVAIRSYSCOM, owned and operated by McDonell-Douglas, er Boeing"
Old March 22nd 04, 08:05 AM
Joe Delphi
be equiped with.
Paul
1. Global Positioning System (GPS) based navigation.
2. A state-of-the-art autopilot, not sure if the original Whales even had
an autopilot.
Not too practical as a bomber with today's modern air defenses, but it might
make a nice standoff weapon launching platform. Put one or two of those Air
Force AGM-86 cruise missiles in the bomb bay and away you go.
JD
Old March 22nd 04, 10:16 AM
sid
"Thomas Schoene" wrote in message thlink.net...
be found.
There was a little blurb in AvWeek some time ago about the USN
revisiting the idea of putting a refueling capability on the E-2s
after some experiences in OIF. Wouldn't it be nice to have a
trappable refuelable MC2 that could keep up with the strike package (I
know, it would take way too much money for the ASEA style antennas to
make that happen).
I hesitate to open this can of worms...But what the hell. Faced with
S-400, FT-2000, and ultra long range AAM threats, MC2A style aircraft
will need susceptability reduction as well in the not too distant
future. The idea that these aircraft can off unfettered in benign
bastions and still do the job is one potential adversaries are
actively attempting to dispell:
http://www.aeronautics.ru/s400triumph.htm
http://www.stormpages.com/jetfight/wwwboard/2359.html
http://www.sinodefence.com/airforce/...nce/ft2000.asp
So that money may be required no matter what a decade from now.
Indeed, the Air Force is already looking at the BWB and MACK concepts
for use as a stealthy KC-X aircraft in the 2015 timeframe.
What such an aircraft would offer is the abilty to loiter with more
bombs per airframe, and also potentially carry something bigger than
2000 lb limit CVWs are saddled with today. And wouldn't it be nice for
a carrier capable aircraft to deliver 8000 lbs out past 1000 nm
unrefueled....But like you said, money for this won't be forthcoming.
Thread drift: Did you that the A-3 was known to have even carried
small cars...
Old April 12th 04, 10:59 PM
sid
(sid) wrote in message . com...
performance.
Here is a realted tidbit in the current AvWeek...
Navy plans to continue dominating the world's oceans despite tight
budgets will require, among other things, strategic aerial tanking
that, in turn, will drive experiments with launching KC-130s from
large-deck aircraft carriers, Rear Adm. Jay M. Cohen, chief of naval
research, says at the annual Navy League convention here. The idea is
to give Navy and Marine aircraft what Cohen terms "overland persistent
tanking."
Wonder how the Hornet Mafia would take to this...
Old April 13th 04, 12:12 AM
Peter Kemp
performance.
tanking."
Some problems with using a KC-130 are....
a. getting them off the deck with a decent load
b. conducting any other ops while the damn thing is on the deck
(you're not going to be striking a Herc into the hangar without a lot
of sawing).
Peter Kemp
Life is short - drink faster
Killfiles redux David Wallace Military Aviation 9 April 12th 04 05:49 PM
Gulf Sickness Redux? DunxC Military Aviation 0 September 18th 03 07:36 AM
NA as alternate...redux Bob Gardner Instrument Flight Rules 1 September 11th 03 11:26 PM
Oshkosh 2003 Redux Sydney Hoeltzli Home Built 97 August 14th 03 05:29 PM
Lightspeed -- Was:Oshkosh 2003 Redux Jack McAdams Home Built 8 August 14th 03 04:19 PM
