#41
Just on a personal note from having a plane on lease back, I wouldnt fly it if
it was over 100 hours. Renters are hell on an airplane. FryGuy wrote: I have a question around a 100 hour inspection requirement. I've had time blocked off at my local FBO for over a month to take a plane this Saturday. Me and another pilot buddy are taking up the coast of North Carolina and are going to hit the airports in the Outer Banks and go to the museum in Kill Devil Hills. I was just told that the aircraft we are renting is over the 100 hour inspection requirement. I asked them if they could get it done between now and then and they said they don't have time. Their argument is that we won't be doing any flight training and therefore the 100 hour inspection requirement is not applicable. I talked with someone at the AOPA and 91.409b says: "Except as provided in paragraph (c) of this section, no person may operate an aircraft carrying any person (other than a crewmember) for hire, and no person may give flight instruction for hire in an aircraft which that person provides, unless within the preceeding 100 hours of time in service the aircraft has received and annual or 100 hour inspection....." The rep at the AOPA said that their interpretation is that since it is a rental plane it is "for hire". I talked with the head A&P Mechanic at the FBO and he said "for hire" only means if their are paying passengers. I know this plane well and I know it is a good plane. I just don't want to violate any FARs. Any help or suggestions would be appreciated. Thanks, Jeff Frey PP-ASEL |
#42
On Mon, 10 Nov 2003 01:19:38 -0800, Jeff wrote:
If your renting it, then it must have a current 100 hr inspection. I do not believe that to be the case, unless you are also carrying persons for hire. The fact that you are renting the airplane is NOT the same as "carrying a person for hire". I suspect your lessor's policy was based on something other than the FAR's. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#43
"Jeff" wrote in message ... I used to use my cherokee 180 as a lease back, when it was over its 100 hours, As the owner, I was the only one allowed to fly it. Who says? We certainly had FBO/Club employees ferrying aircraft that were out of 100 hour. If your renting it, then it must have a current 100 hr inspection. No, only if the instructor is provided with it or you're carrying passengers for hire. I have posted both the regulation AND the FAA legal interpreation of the reg on this thread. There's no requirement for Its not your airplane, How did it cease to be my airplane. The FAA still thinks I'm the owner. so its a plane for hire. Yes, but immaterial. The 100 hour rule doesn't care about that. The operator (the flight school) is responsible for ensuring the maint. on the plane. The flight school is not the operator by the FAA terminology. As the pilot, your responsible for making sure its been completed before flying it. Its one of those things to look for when you look through the log book to verify the annual is up to date and so on. Quite true and frequently overlooked by renters. |
#44
On Mon, 10 Nov 2003 09:35:06 -0500, "Ron Natalie"
wrote: "Jeff" wrote in message ... I used to use my cherokee 180 as a lease back, when it was over its 100 hours, As the owner, I was the only one allowed to fly it. Who says? We certainly had FBO/Club employees ferrying aircraft that were out of 100 hour. If your renting it, then it must have a current 100 hr inspection. No, only if the instructor is provided with it or you're carrying passengers for hire. I have posted both the regulation AND the FAA legal interpreation of the reg on this thread. There's no requirement for Its not your airplane, How did it cease to be my airplane. The FAA still thinks I'm the owner. so its a plane for hire. Yes, but immaterial. The 100 hour rule doesn't care about that. The operator (the flight school) is responsible for ensuring the maint. on the plane. The flight school is not the operator by the FAA terminology. As the pilot, your responsible for making sure its been completed before flying it. Its one of those things to look for when you look through the log book to verify the annual is up to date and so on. Quite true and frequently overlooked by renters. 4 out of 4! |
#45
Jeff wrote in :
I used to use my cherokee 180 as a lease back, when it was over its 100 hours, As the owner, I was the only one allowed to fly it. If your renting it, then it must have a current 100 hr inspection. Its not your airplane, so its a plane for hire. You can certainly set up any more restrictive rules you wish, including limiting flight of the aircraft to only you if it is over 100 hours on the inspection. However, I think if you will check further, you will find that you are incorrect as for USA rules by the FAA. The plane can not be used for hire, meaning air charter, flight instruction offered by the provider of the aircraft, etc. But it most certainly can be rented to a pilot for his own private (personal or business) part 91 flight. ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
#46
Dear Mr. Knox:
I'm afraid you are mistaken. Renting out an aircraft is a commercial operation in itself, and an aircraft cannot be used in any operation for compensation or hire beyond the currency of the 100 hours inspection. An application can be given to the FAA whereby the FAA can extend this by ten hours - but that is the only break there is. I can assure you that when a plane is out of a hundred hour inspection that it cannot be rented out. "James M. Knox" wrote: Jeff wrote in : I used to use my cherokee 180 as a lease back, when it was over its 100 hours, As the owner, I was the only one allowed to fly it. If your renting it, then it must have a current 100 hr inspection. Its not your airplane, so its a plane for hire. You can certainly set up any more restrictive rules you wish, including limiting flight of the aircraft to only you if it is over 100 hours on the inspection. However, I think if you will check further, you will find that you are incorrect as for USA rules by the FAA. The plane can not be used for hire, meaning air charter, flight instruction offered by the provider of the aircraft, etc. But it most certainly can be rented to a pilot for his own private (personal or business) part 91 flight. ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
#47
On Sat, 15 Nov 2003 23:52:41 -0800, Pat Barry wrote:
Renting out an aircraft is a commercial operation in itself True and an aircraft cannot be used in any operation for compensation or hire beyond the currency of the 100 hours inspection. That is NOT what the relevant FAR states An application can be given to the FAA whereby the FAA can extend this by ten hours - but that is the only break there is. I can assure you that when a plane is out of a hundred hour inspection that it cannot be rented out. I can assure you that your opinion does not agree with that of most FSDO's. Which FSDO supports your thesis? Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#48
Dear Mr. Knox: I'm afraid you are mistaken. Renting out an aircraft is a commercial operation in itself, and an aircraft cannot be used in any operation for compensation or hire beyond the currency of the 100 hours inspection. An application can be given to the FAA whereby the FAA can extend this by ten hours - but that is the only break there is. I can assure you that when a plane is out of a hundred hour inspection that it cannot be rented out. That statement is certain to **** some of the natives off. I'm sure the "armchair lawyers" of the group (they know who they are) will start listing and quoting their sacred "FARS" along with their own interpretation of such, in anticipation of being elevated to the position of "Armchair Chief Justice". |
#49
"Ron Rosenfeld" wrote in message ... On Sat, 15 Nov 2003 23:52:41 -0800, Pat Barry wrote: Renting out an aircraft is a commercial operation in itself True and an aircraft cannot be used in any operation for compensation or hire beyond the currency of the 100 hours inspection. That is NOT what the relevant FAR states An application can be given to the FAA whereby the FAA can extend this by ten hours - but that is the only break there is. I can assure you that when a plane is out of a hundred hour inspection that it cannot be rented out. I can assure you that your opinion does not agree with that of most FSDO's. Which FSDO supports your thesis? None for long, if Pat posts their name here. ![]() It must have been some sort of misunderstanding ... |
#50
Pat Barry wrote in :
Renting out an aircraft is a commercial operation in itself, It's renting of a piece of property. It is a commercial operation and will require the renter to hold a state sales certificate (although not have to pay state tax in most states). aircraft cannot be used in any operation for compensation or hire beyond the currency of the 100 hours inspection. But it can be flown by the renter, or his pilot (including a flight instructor *the renter provides*, as long as it is in annual and otherwise airworthy. No 100 hour inspection is required. I can assure you that when a plane is out of a hundred hour inspection that it cannot be rented out. I hate to quote FSDO web sites, because they are frequently in error. But from, for instance, the Albany FSDO website: "Aircraft rental by itself isn't "for hire," and applicants bring the airplane to me for the test. However, the aircraft may have a recurring AD that requires compliance every 100 hours, so although the 100-hour inspection may be unnecessary, AD compliance may be." More officially, here's an FAA Chief Counsel letter interp: May 3, 1984 Mr. Perry Rackers Jefferson City Flying Service Dear Mr. Rackers This is in reply to your request of May 1, 1984, that we render an opinion regarding the applicability of the 100-hour inspections requirement of Section 91.169(b) of the Federal Aviation Regulations to rental aircraft. Section 91.169(b) of the Federal Aviation Regulations provides that, except as noted in Section 91.169(c), a person may not operate an aircraft carrying any person, other than a crewmember, for hire, and may not give flight instruction for hire in an aircraft which that person provides unless, within the previous 100 hours of time in service, the aircraft has received either an annual or a 100-hour inspection. If a person merely leases or rents an aircraft to another person and does not provide the pilot, that aircraft is not required by Section 91.169(b) of the Federal Aviation Regulations to have a 100-hour inspection. As noted above, the 100-hour inspection is required only when the aircraft is carrying a person for hire, or when a person is providing flight instruction for hire, in their own aircraft. If there are any questions, please advise us. Sincerely, /s/ Joseph T. Brennan Associate Regional Counsel I'm afraid you are mistaken. Wouldn't be the first time... but not in this case. jmk |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 06:07 AM |
| Home Inspection Listings | Patrick Glenn | Home Built | 4 | April 26th 04 12:52 PM |
| 51st Fighter Wing betters rating to ‘excellent’ with inspection | Otis Willie | Military Aviation | 0 | February 21st 04 12:29 AM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
