Anyone here flown a Glasair 1?
Old January 2nd 04, 04:19 PM
Tom Andersen
Default Anyone here flown a Glasair 1?
I'm considering buying a completed Glasair 1 FT with an IO360 and FP prop.
I fly a Grumman Cheetah but want a lot more speed and range. I cannot find
any V-speeds on the net for the Glasair 1, only for the Glasair ll. What
kind of TO and LDG distances does it require?
Tom Andersen
Greensboro NC
Old January 2nd 04, 04:31 PM
Ed Wischmeyer
Don't have the V-speeds, but double check the pitch and yaw stability at
aft c.g., especially at slow speeds. Double check that this plane's
envelope is as per factory recommendations, and find out if the
prototype was spin tested.
Ed Wischmeyer
Old January 5th 04, 08:13 AM
Bruce Gray
If you want the real information, call New Glasair at 360 435-8533 and talk
to Ted or Tom Setzer. They designed the airplane. Or you can come over here
and talk with other GI pilots.
Bruce
www.glasair.org
"Tom Andersen" wrote in message
r.com...
find
Tom Andersen
Greensboro NC
Old January 5th 04, 07:12 PM
wmbjk
prop. I fly a Grumman Cheetah but want a lot more speed and range. I
cannot find any V-speeds on the net for the Glasair 1, only for the
Glasair ll. What kind of TO and LDG distances does it require?
From a G1 brochure - stall w/flaps @ gross weight 62mph, take off roll
gross 700 ft., landing roll gross 530. Best rate 110, Best angle 75,
Maneuvering 145, Never exceed 260. Many G1s have wingtip extensions
which lower the stall speed etc. If yours doesn't have them, then you
could add them. Of course every example is going to be slightly
different. Empty weight on which those specs were probably based is 960
pounds. If the one you're looking at is fatter than that then .....
There are quite a few things you should be looking for in terms of
updates. Best to get with New Glasair for that advice. IIRC, the
archives at http://www.glasair.org/ have some detailed articles about
the progression of Glasair models as well as lots of other stuff that
you'd probably find useful.
Advice on flying Pitts with Haigh Locking Tailwheel Ditch Home Built 19 January 4th 04 11:18 PM
Lowest cost per mile flown motor- 2 stroke Bruce A. Frank Home Built 0 July 2nd 03 07:25 AM
