Jay Honeck wrote:
Actually, Jay, if you reread Denny's post carefully, I don't think this is what he's seeing or refering to as "some owners lurch from crisis to crisis" but it's not worth addressing further. The only reason many Lightspeed owners have NOT had repeated problems with broken wires at the plug is because they specifically lay the battery box on the floor, or tuck it in a side pocket. This removes the weight of the battery box from the inadequately designed wire and plug assembly, and keeps the wires from breaking. NOW it has come to light that laying the battery box on the floor (or tucking it in a pocket) can result in a conflagration of your aircraft. Actually I think that's overstating the possible outcomes considerably. What happens is this. The battery box shorts. The batteries get hot. The battery box gets hot. The battery box begins to melt. The batteries lose contact w/ the deformed battery box, the short circuit is broken, and the heating stops. The worst case is if the battery box happens to get hot enough to melt low-temperature plastic trim, which can be expensive and costly to replace. The fabrics used in the interior of the aircraft had durned well better withstand a much higher temperature without igniting, or someone installed the wrong stuff. Likewise, it should not get hot enough to ignite paper. I discussed this in detail with the Lightspeed engineer. DH, who has extensive training in fire hazard prevention, concurs. Of course, there can always be some combination of factors which lead to a different result. So I wouldn't worry that your Lightspeed battery box is likely to cause conflagration of your aircraft. However, I would make sure you don't place it somewhere which might melt and cost you time and $$. For example, we've been securing our 20K and 25XL battery boxes with velcro (sewn to the plane interior, glued to the battery box). This is gonna stop, because velcro melts at rather low temperature and melted velcro would trash my interior panels. A fabric pocket should actually be a good place, provided the fabric meets standard aircraft flammability tests. Cheers, Sydney This is, indeed, a "crisis" of quality control, in my opinion. And, as I have repeatedly stated in the past, is truly a shame, as we absolutely, positively LOVE our Lightspeed headsets. |
| Thread Tools | |
| Display Modes | |
| RG Battery Charger by Jim Weir in Kitplanes | Kevin O'Brien | Home Built | 4 | January 6th 05 02:19 AM |
| Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 04:07 PM |
| For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 06:18 AM |
| Plane with no stall warning device? | Roy Smith | General Aviation | 23 | February 17th 04 04:23 AM |
| Lightspeed -- Was:Oshkosh 2003 Redux | Jack McAdams | Home Built | 8 | August 14th 03 04:19 PM |
