Lightspeed Battery Box Warning
Old July 9th 03, 04:13 PM
Sydney Hoeltzli
Steve House wrote:
Right - the accusation that I'm an idiot is "demonstrating expertise"
Where did anyone accuse you of being an idiot?
Quote carefully, now --- it's all on Google, go on, have a good look...
Just
because it's the internet does not mean that the normal practices of polite
human interaction are somehow suspended.
Exactly my point. Do you begin "polite human interaction" by
responding to someone's information with "assuming this is legit..."?
That's damned rude in my book, and won't make you welcome in the
conversations I've experienced.
I'm an old hand at the Net and Usenet, having used it daily since about
1980.
Without improving your ability to read accurately and communicate
precisely, it would appear.
Personally when I seek information, I start out with questions.
"Is it important to purchase only a TSO'd headset? What does TSO really
mean? Do pilots find that TSO'd headsets are more reliable than
non-TSO'd headsets?" not by making a buttload of assertions including
a total fabrication about battery boxes bursting into flame.
The latter will get you a faster response for sure, but evidently
not of the kind you find enjoyable.
How can someone who asserts he's been on USENET for more than a decade
not know this? Beats me.
Cheers,
Sydney
  #32
Old July 9th 03, 04:23 PM
Sydney Hoeltzli
I'm not really excited about buying any of the 15/20/25/30 K,XL,G
series because they seems pretty flimsy, have extraordinarily lousy
passive attenuation (read: LOUD out of active cancellation above 300 Hz),
and artificually boost the radio's voice frequencies to an uncomfortable
level. I'm sure the boosting is for "clarify" of old ears that are
already fried from 40 years of naked flying, but I'm trying to keep mine
good.
Cory,
I'm afraid I don't follow your critique of the K/XL/G series.
The radio's voice frequencies can be adjusted to any level you
like with the volume control. I have very good ears and the
level is not uncomfortable, in fact it is too low on the
minimum volume setting in our plane. If something was uncomfortable,
and turning down the volume on the headsets didn't fix it, then
perhaps the radio volume was turned up too high? We are able
to combine most headsets in our plane and find suitable settings
of intercom/radio/headset volume, but it does take a little
tweaking when a new headset comes into the mix. I'm a little
puzzled because surely you must have tried this.
You're correct about the poorer Lightspeed passive attenuation.
It's a direct function of the attraction for Lightspeed owners,
the comfort. As you probably know, good passive attenuation in
muff-style headsets is a function of ear seal, and ear seal is
a function to some degree of clamping force.
I don't find the K/XL/G series flimsy except at the poorly-
designed plug/battery box configuration. However, if you do,
I believe you would find the same to be true of the QFR series.
My previous headset was a Flightcom Eclipse, regarded by many
as flimsy, and it served me well so I think there's an issue
of how gentle one is on equipment.
If you want good passive attenuation and sturdiness, perhaps
you would prefer a set of Dave Clamps?
Best,
Sydney
  #33
Old July 9th 03, 04:54 PM
In rec.aviation.owning Sydney Hoeltzli wrote:
: wrote:
: I'm not really excited about buying any of the 15/20/25/30 K,XL,G
: series because they seems pretty flimsy, have extraordinarily lousy
: passive attenuation (read: LOUD out of active cancellation above 300 Hz),
: and artificually boost the radio's voice frequencies to an uncomfortable
: level. I'm sure the boosting is for "clarify" of old ears that are
: already fried from 40 years of naked flying, but I'm trying to keep mine
: good.
: Cory,
: I'm afraid I don't follow your critique of the K/XL/G series.
: The radio's voice frequencies can be adjusted to any level you
: like with the volume control. I have very good ears and the
: level is not uncomfortable, in fact it is too low on the
: minimum volume setting in our plane. If something was uncomfortable,
: and turning down the volume on the headsets didn't fix it, then
: perhaps the radio volume was turned up too high? We are able
: to combine most headsets in our plane and find suitable settings
: of intercom/radio/headset volume, but it does take a little
: tweaking when a new headset comes into the mix. I'm a little
: puzzled because surely you must have tried this.
What I meant was that it has an active filter in the mix that
boosts the voice frequencies from the radio/intercom. That range
(1kHz-3kHz or so) is what makes speech inteligible, and so they boosted it
to make the radios sound "clearer" and "easier to hear." For me, this
yields a harsher sound in those voice than a plain headset. I don't find
it necessary to artificially boost those frequencies for the radio to be
heard over the intercom. The level on the batt box simply adjusts the
gain, but doesn't adjust these boosted frequencies. While a bit
confusing, that's what I meant. It's not just a level thing.
: You're correct about the poorer Lightspeed passive attenuation.
: It's a direct function of the attraction for Lightspeed owners,
: the comfort. As you probably know, good passive attenuation in
: muff-style headsets is a function of ear seal, and ear seal is
: a function to some degree of clamping force.
Sure. That's why they're touted as very comforable (which they
are). Most GA planes are fairly well sound insulated at the frequencies
that are easy to insulate (1kHz). My plane with minimal internal sound
damping has lots of rattle inside, which makes it unusually noisy in the
1kHz-5kHz range... again the same frequencies that the LS-15/20/25/30
boosts. In fact, I saw a review that showed appreciable spill-over from
the LS headsets in that range. It's a side-effect of attenuating the
100Hz-300Hz range that it actually *boosts* the noise in the 1kHz range or
so. Not pleasant at full-power climbout.
: I don't find the K/XL/G series flimsy except at the poorly-
: designed plug/battery box configuration.
The telescoping action of each side has broken on two separate
friends' headsets. One 25XL, the other 15K.
However, if you do,
: I believe you would find the same to be true of the QFR series.
: My previous headset was a Flightcom Eclipse, regarded by many
: as flimsy, and it served me well so I think there's an issue
: of how gentle one is on equipment.
The battery box doesn't bother me all that much. In fact, I like
the XC-2 and 30G ability to plumb music right in to the headset. If it
truely is 28 dB passive without a vice-grip, then the 10 dB of active it
provides will help cut down the engine even a bit more.
: If you want good passive attenuation and sturdiness, perhaps
: you would prefer a set of Dave Clamps?
Kinda like buying a Sony VCR. It's still built by the lowest
Korean/Japanese/Philpines/Chinese bidder, but stick a name on it and
charge 2x the price. It's rather ridiculous that aviation headsets cost
so much. Even if DC or Bose is slightly better, it certainly isn't worth
the shameless gouging in price.
FWIW
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
  #34
Old July 9th 03, 05:01 PM
Paul Tomblin
In a previous article, "Steve House" said:
Right - the accusation that I'm an idiot is "demonstrating expertise" Just
Jim never called you an idiot. I don't think anybody did until now. But
*now* I'm going to to call you an idiot, because you obviously are one.
human interaction are somehow suspended. I'm an old hand at the Net and
Usenet, having used it daily since about 1980. I'm also a very new student
Bull****. Nobody who was using Usenet in 1980 does TOFU posting. Up
until the never ending September of 1993, anybody who didn't learn to trim
their quoted text would have been hounded off of any reasonable newsgroup.
correction where it was in error. I suppose we egg's should just sit
silently in rapturous awe at the feet of the Masters. Thanks for making me
No, people who make wrong statements should take correction without
accusing the person making the corrections of being arrogant.
feel so very welcome to the group.
You're not welcome to the group. People who can accept correction are.
So are people who don't lie about their qualifications.
Paul Tomblin , not speaking for anybody
There is no substitute for good manners, except, perhaps, fast reflexes.
  #35
Old July 9th 03, 05:02 PM
Ron Natalie
"Jim Weir" wrote in message ...
Because everything I do is kit. To do a decent job with ANR requires you to
work with surface mount devices roughly the size of an FAA inspector's heart.
But this is still several times larger than his brain ;-)
  #36
Old July 9th 03, 05:32 PM
Dan Luke
"Jay Honeck" wrote:
I am buying our fourth ANR headset at OSH 2003 later this month.
Thus, soon a Garmin 196 will be resting comfortably on my yoke, God
willin'
and the crick don't rise...
By golly, that's my kind of guy. If I come home from OSH without holes worn
in my credit card, I feel like I haven't enjoyed the full experience.
Someone told me they have aerobatics displays and stuff at the show - is
that true?
See you at the vendors booths...
Dan
C172RG at BFM
  #37
Old July 9th 03, 07:04 PM
SteveH
FYI - top posting is the current norm in many Usenet groups, especially the
MS tech support groups where I spend most of my time. With newsreaders like
Outlook Express, some people find embedded responses can be more difficult
to read than the top posts.
"If it is legit.." was not impuning any individual report but rather the
blanket assertion that flaws and failures in use are endemic to Lightspeed,
which has been alleged, not in your post nor about this particular problem,
but rather in other threads where people have criticised Lightspeed's
quality control.
A battery pack that is hot enough to melt its casing and emit smoke is on
the verge of combustion and even if it did not ignite itself it seems to me
to present a risk that it could cause more flammable objects in contact with
it to ignite. Heck, Dell Computer recalled a batch of Nicads battery packs
for some of their laptop models a year or so ago because of nearly identical
overheating problems that had, in fact, resulted in full blown fire in
several cases.
"Sydney Hoeltzli" wrote in message
  #38
Old July 9th 03, 07:14 PM
Jim Weir
Now, now, Ron, let's not split hairs. PMA is almost always issued
simultaneously with the TSO, but it is the PMA documentation that sets the
inspection standard(s).
"Ron Natalie"
-If you've got a TSOA, you've also got manufacturing authority.
http://www.rst-engr.com
  #39
Old July 9th 03, 08:05 PM
Peter Duniho
"SteveH" wrote in message
lol...
Just because it's the norm, that doesn't make it right. It just means a
bunch of newbies are posting in that newsgroup.
How in the WORLD does the newsreader being used affect how easy it is to
READ a traditionally quoted post versus a top-posted post?
As far as your example of Dell battery packs goes...there's a big difference
between the available current in a laptop battery and a battery pack driving
a headset.
Pete
  #40
Old July 9th 03, 08:19 PM
Peter Duniho
"Paul Tomblin" wrote in message
Actually, Microsoft actively encouraged HTML posting in the microsoft.*
newsgroups
I don't know what you mean by "actively encouraged". However, even if true,
I fail to see what HTML posting has to do with the current topic, which is
top posting.
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 02:19 AM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 04:07 PM
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 06:18 AM
Plane with no stall warning device? Roy Smith General Aviation 23 February 17th 04 04:23 AM
Lightspeed -- Was:Oshkosh 2003 Redux Jack McAdams Home Built 8 August 14th 03 04:19 PM
