Maule Turbine
Old August 1st 03, 02:17 AM
kevin
Default Maule Turbine
Does anyone have any experience with the Maule with the Allison turbine
engine ? The Maule with the Lycombing IO-540 is $170.M , where the
MT7-420 is going for $470.M new. I would have to add about $75.M in
options for either bird. What do you think about the Allison turbine in
a Maule ?
Thanks
Old August 1st 03, 02:30 PM
Dennis O'Connor
You are joking, right?
Look, the Maule is a fine airplane and does it's thing well, which is short
field and grass operations... It is not a turbine bird, and installing one
is a waste of money... Unless you are going into the bush of africa or asia
where 100LL is not available, stick to the Lycoming...
Denny
"kevin" wrote in message
news:6kiWa.22942$cF.9271@rwcrnsc53...
a Maule ?
Thanks
Old August 1st 03, 02:58 PM
G.R. Patterson III
a Maule ?
The turbine carries 35 pounds more and takes the same distance to clear a
50' obstacle. The major difference is the 2800 fpm climb rate versus the
1500 fpm for the piston engine. The turbine goes for $450,000. There are
several models of 235 hp planes, one of which costs $139,600.
So. That climb rate will set you back over $300,000 and burn twice as much
fuel. It wouldn't be worth it to me.
Check http://www.mauleairinc.com for figures.
George Patterson
The optimist feels that we live in the best of all possible worlds. The
pessimist is afraid that he's correct.
James Branch Cavel
Old August 1st 03, 03:04 PM
Maule Driver
Seems like a very fine toy. Wish we had one... let's see, we've got Jet-A
on our lit grass strip. Imagine a night landing in the back yard with the
whine of that turbine as we select beta thrust. Wheeeee!
.... perhaps add some amphious floats.
Just need to increase our wealth by an order of magnitude... or two.
a Maule ?
Thanks
Old August 1st 03, 03:08 PM
G.R. Patterson III
engine ?
You might also want to check into the status of the diesel they've been
trying to get certified. That should be a reasonably priced aircraft
with performance similar to the 235 but using jet-A. I spoke with Ray
Maule about it last year, and he said it was going well, but I don't see
anything about it on their web site anymore.
George Patterson
James Branch Cavel
Old August 1st 03, 05:35 PM
Dave Lyjak
G.R. Patterson III wrote:
engine ?
From AvWeb:
This week at OSH, Maule debuted an M-9 fitted with SMA's SR 305-230 aerodiesel,
which was first certified in Europe a while ago and is now poised to make
inroads in the U.S.
Dave
Old August 1st 03, 10:45 PM
kevin
Denny
I was not talking about a conversion, you can buy a new Maule from the
factory with the Allison engine. I was looking at the difference of
cruise speed 164 with the Lycoming as opposed to 190 with the Allsion.
The 2800 fpm climb is also tempting.
a Maule ?
Thanks
Old August 1st 03, 10:48 PM
kevin
a Maule ?
One big difference is the cruise speed 164 for the lycoming, and 190
for the Allison. But as you say the price difference is huge.
Thanks
George Patterson
James Branch Cavel
Old August 1st 03, 11:24 PM
Newps
The slower Maule will go a lot further between fill ups.
Old August 2nd 03, 02:42 AM
kevin
This is true. 15gph as opposed to 25 for the turbine.
turbine in microturbine generator for aircraft? Shin Gou Home Built 19 December 26th 04 03:19 PM
turbine propeller sebastian Home Built 19 March 21st 04 01:47 AM
earliest turbine powered helicopter? Charles Gray Military Aviation 7 January 3rd 04 12:35 AM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 10:41 AM
WTB: Turbine ignition exciter unit, single plug Juan E Jimenez Aviation Marketplace 0 August 25th 03 01:48 AM
