Dennis O'Connor wrote:
You are joking, right? Look, the Maule is a fine airplane and does it's thing well, which is short field and grass operations... It is not a turbine bird, and installing one is a waste of money... Unless you are going into the bush of africa or asia where 100LL is not available, stick to the Lycoming... Denny I was not talking about a conversion, you can buy a new Maule from the factory with the Allison engine. I was looking at the difference of cruise speed 164 with the Lycoming as opposed to 190 with the Allsion. The 2800 fpm climb is also tempting. "kevin" wrote in message news:6kiWa.22942$cF.9271@rwcrnsc53... Does anyone have any experience with the Maule with the Allison turbine engine ? The Maule with the Lycombing IO-540 is $170.M , where the MT7-420 is going for $470.M new. I would have to add about $75.M in options for either bird. What do you think about the Allison turbine in a Maule ? Thanks |
| Thread Tools | |
| Display Modes | |
| turbine in microturbine generator for aircraft? | Shin Gou | Home Built | 19 | December 26th 04 03:19 PM |
| turbine propeller | sebastian | Home Built | 19 | March 21st 04 01:47 AM |
| earliest turbine powered helicopter? | Charles Gray | Military Aviation | 7 | January 3rd 04 12:35 AM |
| Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 10:41 AM |
| WTB: Turbine ignition exciter unit, single plug | Juan E Jimenez | Aviation Marketplace | 0 | August 25th 03 01:48 AM |
