"Mike Noel" wrote in message ... Thanks for the replies. I ordered 3 new CCA-1550 drains from Aircraft Spruce. The total with priority USPS shipping was about $30. Curtis Valve has a nice application chart on their web site that lists which valves are used in which aircraft. In the Piper their is no safety wire involved. Looks like it is just a friction fit with the pipe threading. Is it just metal to metal with no special sealant? -- Mike in Tucson (AVQ) Archer N54405 Pipe threads don't *require* a sealant. However, I would recommend a dab of fuel lube. You could also use some of the teflon goo, but DON'T use teflon tape. KB |
| Thread Tools | |
| Display Modes | |
| Cleaning up brushes/dope? | Michael Horowitz | Home Built | 5 | June 23rd 11 03:11 AM |
| Windsheild cleaning | OSKI 3 | Home Built | 10 | June 27th 04 08:48 PM |
| RAM posting are fast going down the drain .. .. | Alfred Loo | Military Aviation | 2 | April 8th 04 11:12 PM |
| Cleaning up a reamed hole? | Boelkowj | Home Built | 5 | March 25th 04 02:32 AM |
| Kerry begins circling the drain: | Tarver Engineering | Military Aviation | 0 | February 12th 04 07:04 PM |
