"Dave Stadt" wrote in message .com... I can verify that this procedure works with other model Cessnas also. It won't work with a Cardinal or later 210's. |
"Ron Natalie" wrote in message m... "Dave Stadt" wrote in message .com... I can verify that this procedure works with other model Cessnas also. It won't work with a Cardinal or later 210's. Yep, you will have to borrow the neighbors 172. |
In article , "Dave
Stadt" wrote: I can verify that this procedure works with other model Cessnas also. and piper wheels. 1. I remove the valve core (deflate the tire) 2. I place the wheel flat on the cement hangar floor under the wing of my 182. 3. I hang onto the wing strut to keep from falling over 4. I place my feet radially outward from the center of the wheel such that my heels are together right at the wheel rim. 5. My 205 lbs is usually enough to force the tire bead downward off the rim. Sometimes, I have to alternate putting all my weight first on one heel and then the other. 6. Turn the wheel over and do the other side. 7. Remove the bolts holding the wheel halves together. -- Bob Noel |
| Thread Tools | |
| Display Modes | |
| Tire Changer | Juan Jimenez | Aviation Marketplace | 0 | August 19th 04 03:58 AM |
| Tire inflation pressure | Paul Lee | Home Built | 80 | November 19th 03 08:56 AM |
| Nosewheel Shimmy and Scalloped Tire Redux, Plus | Larry Smith | Home Built | 2 | September 15th 03 05:03 PM |
| Scalloped Nosewheel Tire | Larry Smith | Home Built | 7 | September 12th 03 10:16 PM |
| Tire talc...baby powder? | No Spam | Owning | 12 | August 8th 03 06:03 PM |
