Kyler Laird wrote in news:kgoo41-gc5.ln1
@jowls.lairds.org: On our way home not long ago we landed in Denver with our oxygen getting low. I asked for a fill and they gave it their best shot but our configuration didn't leave them sufficient space for all of the adapters they needed to use. Any ideas on installing something like this in an Aztec? Maybe a simpler option, given that the FAA will get involved in any permanent installation. As I understand it, the real problem is not with the fill port, but rather with the adapters some FBO's need not fitting into the space. Go to your local welding gas supply company and have them order or make a short (12" to 18") extension hose. One end fits your fill port. The other end can be the same as your fill port *or* it can be some other connector if you are finding them more common at FBO's. Either way, no adapters near the aircraft fill port are needed. ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
| Thread Tools | |
| Display Modes | |
| hi alt oxygen | Arquebus257WeaMag | Military Aviation | 62 | March 28th 04 05:57 PM |
| D'Amato's Role Investigated in La Guardia Airport Deal | Roy Smith | General Aviation | 0 | December 25th 03 06:47 AM |
| Why a static port? | Paul Mennen | Owning | 11 | August 19th 03 05:58 AM |
| Is a static port a precision thing? | Larry Smith | Home Built | 8 | August 12th 03 11:26 PM |
| Portable oxygen system suggestions... | Julian Scarfe | Owning | 5 | August 12th 03 01:02 AM |
