First I would try to get rid of the vibration. Find someone with a
helicopter balancer. You might try replacing the stiff wire with flexible silicone jacket welding cable of the same size since this will take much more flex before it breaks. A small loop at the terminal will tend to distribute the flex over a larger length and help stop the breaking where the flex is concentrated. Crimp terminals are better than solder in high vibration enviroments. On Wed, 10 Dec 2003 18:47:05 GMT, "gix" wrote: Hi, I 'm an italian student(then excuse for my english)and i've a problem with my alternator(120 ampere installed on a Lycoming 360);my problem is the broken of the wire on the terminal of my alternator,the terminal is intact but the wire result as cut. The reason for me is the high vibraction in the zone of connection of the terminal on the alternator and I don't know if the broken owe by the rigidity of the wire(the size is for the positive 4 AWG and negative 6 AWG,the type of the wire is Raychem for aereonautical application)or by the wrong crimp. I wont ask at you that type of the terminal is indicated use in this case?(I utilize a Amp PIDG terminal form square);exist other possibily cause? Thank you in advance |
| Thread Tools | |
| Display Modes | |
| IFR Terminal Procedures Tool | Todd Neidinger | Instrument Flight Rules | 12 | February 4th 05 02:46 AM |
| This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. | Scott Ferrin | Military Aviation | 29 | August 31st 04 05:20 AM |
| Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 04:24 AM |
| Terminal velocity of bombs? | BackToNormal | Military Aviation | 32 | September 24th 03 05:41 AM |
