#11
On 17-Dec-2003, "Michael 182" wrote: How does an electronic altimeter work? Is there some kind of pressure sensor? Yes. The sensing element is in essence a solid-state strain gauge that detects atmospheric pressure. This is similar to the mechanisms used in many blind encoders. The Casio watch and similar electronic altimeters include means for correcting for variations in barometric pressure. (However, in the case of the Casio the adjustment is unfortunately not in terms of sea level pressure but is rather just a means to adjust the altitude readout. For aviation use you set it on the ground to the airport elevation and adjust it in flight by setting it against the airplane's altimeter. While there are some very sophisticated piezoelectric pressure sensors that allow for an electronic altimeter to be as sensitive as the good old expanding bellows mechanical kind, the inexpensive strain gauge mechanism is not quite as good. Adequate for blind encoding or an altitude watch where required resolution is on the order of 50-100 feet, but not good enough for use on an instrument approach to low minimums. ______ Elliott Drucker |
| Thread Tools | |
| Display Modes | |
| Bombs Over Baghdad Video Link, WATCH IT | kyrustic | Military Aviation | 6 | May 2nd 04 03:30 AM |
| Where can I watch planes? (Northern NJ) | TeleTechnician | General Aviation | 6 | November 21st 03 04:09 AM |
| Anyone watch Discovery Wings this afternoon (Friday 08/01/03) | Jim Atkins | Military Aviation | 0 | August 2nd 03 08:52 AM |
