Ben,
These parts are available commercially with the adapters for the hose. An A&P can get them. They have AN/MS numbers. We were issued them where I work. Make sure you read the Maintenance manual for your aircraft. Most Small GA aircraft strut pressures are below 200 PSI. The strut pressures for our planes (Turbo-props and Regional Jets) range from 500 to 2000 PSI, depending on the temperature. The cost may be prohibitive. The tank will cost $80-150 to buy depending on the size and the regulator could be up to $400. Leasing a tank could also be an option. Hope this helps, Michelle Ben Jackson wrote: I'd like to get a tank of N2 to keep around to fill my struts. I assume the welding supply place that will sell me the tank can sell me a regulator that will get me into the 300-500psi range (right?). Where can I get the hose with appropriate (schraeder?) valve for the strut end? Am I looking for something that will thread on, or does it clamp on like a bicycle pump? With a clamp-on type, how do you avoid being sprayed with oil and losing pressure as you disconnect? -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
| Thread Tools | |
| Display Modes | |
