#34
I was basically thinking of that very circuit in a small PLD (you wield a hammer long
enough and everything starts to look like a nail). You also need at least an inverter to realize a counter. For one light on at a time, which I think is what the 'rabbit' does, you'd need a little bit more, especially if you wanted it to recover should it hiccup. A johnson counter (last register output inverted and fed back to the first) would make the all the lights go on in sequence before any started going off. So, to your timer and shift registers, add a package with a gate. For the cost and circuit board complexity, you'd probably come out ahead using a small PLD (there are several in the $1-2 range that would suffice) , assuming you had a way to program it. You could also use a 4 bit counter, timer and 16 line decoder (7493, 74154 and 555). 16 Leds is probaby enough for a Rabbit, I think most only have about 10 strobes. I'd be tempted to use white LEDs. In any event, since he was asking, I presumed that working with logic chips was probably beyond his capability, so I was trying to come up with solutions that would not require any logic design. (I guess that means a CPLD would be even further out of reach of course). If he could live with orange lights(or perhaps green if you can still find the green neon lamps), you could also do it with NE-2 bulbs and resistor and capacitor for each bulb. It is a ladder network of relaxation oscillators that depends on the neon lamp's high off resistance and low on resistance to make it flash, and the ladder network makes them flash in sequence. Maurice Givens wrote: Ray, I'm shocked!! 1 timer, 2 16-bit shift registers, and 32 LED's Maurice Ray Andraka wrote in message ... Jay, There are inexpensive christmas light sequencers available. They generally use 3 circuits with every third bulb on the same circuit. I had one a few years ago that had a switch to select chase, random or all on, and a knob to vary the rate. Cost no more than 3 or 4 bucks and came with the lights. That is a little bit different than the rabbit, which has only one light on at a time, so it may not achieve the effect you are looking for. A possible low tech solution would be a motor driving a cam that closes a series of microswitches in sequence...easy enough to produce by someone with a little bit of mechanical talent and not much electrical know-how. A higher tech solution would be to use electronics consisting of a programable logic device and a set of solid state switches to switch the current. Could also be done with a computer with a relay card plugged into it, but would need a little bit of programming to make it work (such relay cards are available from electronics firms like Jameco). The computer solution would be a bit of overkill, but could be done with off the shelf stuff. Jay Honeck wrote: Today a pilot-guest had the coolest idea for the side-entrance to our lobby: "Chasing" lights recessed in the drop-ceiling tiles, leading to the main lobby area, that look just like the "rabbit" lights that lead to the approach end of a runway! (Background: Over half of our guests come in the "wrong" door to our lobby, which leads more directly to the pilot's lounge than to the reservation desk. As a result, we've often got people milling around looking "lost" in the pilot's lounge. These chasing lights would "lead" them to the correct area, and be really cool looking, too.) So, I stopped at the local Rat Shack, and found the perfect little 12 volt blue lights, 1/2 inch in diameter. (Blue would be a bit toned-down from white strobes!) It would be a simple matter to drill 1/2 inch holes in the ceiling tiles, every 12 inches or so, and push them through the tiles from above so that only the blue "dome" was sticking out through the hole. I think 12 volt lighting would be safer in the ceiling than 120 volt Christmas lights, as a couple of people have suggested... Here's the problem: How to sequence them? The guys at Radio Shack had NO advice at all -- they were all stumped. The lights should flash sequentially pretty fast, but I think they'd look pretty stupid if they weren't coordinated properly. I'd also want to incorporate a motion detector on/off switch, so that they weren't running all the time. Anyone got any ideas? Are there affordable electronic "sequencers" available? Is this something RST Engineering could build for me, Jim? Thanks! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
| Thread Tools | |
| Display Modes | |
| NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 06:12 AM |
| Please help -- It's down to the wire | Jay Honeck | Home Built | 12 | July 14th 04 07:05 PM |
| LEDs for Nav Lights - Jim Weir | Scott Gettings | Home Built | 3 | February 17th 04 02:53 AM |
| Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 05:02 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
