Would have been nice if Piper had put the sump drain actuator *outside* on the
belly near where you need to hold the collection bottle, wouldn't it? Even if it were behind some sort of door (like it is on the inside), it would have avoided all the passenger induced damage, as well as many of the gas spots on asphalt ramps. (I assume the 235 has a similar set up as a Six with the push down lever thingy behind the cheesy plastic door with the spring hinges). Maybe someone can come up with an STC to put the drain actuator on the belly where it belongs. Jay Honeck wrote: Thanks for the help. There is a very fine product called "JB Weld" that my A&P recommended to me. It works extremely well on the plastic instrument panel parts. JB Weld is amazing stuff. It comes in two separate tubes, and you mix it together like epoxy. It stays workable for over an hour, and "gravity smoothes" itself into a very nice surface. When it is fully cured (overnight) you can drill it, sand it, saw it -- just like the original plastic. I have used it to repair several parts, and -- after painting -- you can't see the repair at all. On the last thing I repaired (the stupidly designed fuel sump access door that every back-seat passenger seems to step on and break) I actually used it to not only fix the break, but I was able to get it to "surround" and encapsulate a small piece of aluminum sheet metal, to act as a reinforcement. To further strengthen the piece, I drilled and pop-riveted the aluminum piece to the plastic before gluing. The JB Weld fills voids extremely well. (Every time I fix this stupid part, I make it stronger. This is my third attempt -- if my kids break it again, I'm installing a piano hinge on the danged door!) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
| Thread Tools | |
| Display Modes | |
| Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 03:41 AM |
| Instrument panel labelling options | John Galban | Home Built | 12 | November 18th 04 11:42 PM |
| Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 06:54 PM |
| replacing plastic panel overlay w/aluminum | Dave | Owning | 7 | January 10th 04 11:52 PM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
