Need gauge help/information
Old February 15th 04, 06:05 AM
dave
Default Need gauge help/information
I'm going to be re-doing the panel in my old Bonanza and would like to
get rid of the gauge cluster i currently have and replace it with
something that can fit in a standard instrument hole.
The cluster takes up a lot of real estate.
I need fuel pressure, oil pressure, ammeter and fuel gauge in the same
hole. And possibly CHT.
The oil pressure and fuel pressure are currently the direct feed type,
ie lines are directly fed into the gauge.
Is there anything out there that can satisfy my needs or close.
I have room for an additional instrument hole if needed.
Thanks
Dave
Old February 15th 04, 02:01 PM
Rich
Before you install it... and probably before you buy it, I suggest you
check with your local FSDO about getting approval for replacing the
factory guages.
I strongly believe it will be VERY hard to get approval!
Rich
Thanks
Dave
Old February 15th 04, 04:22 PM
G.R. Patterson III
It's usually extremely difficult to get the FSDO to allow you to replace factory
instruments such as fuel gauges. Check out back issues of AOPA Pilot from 2001
to get some idea of what can be done. They fixed up a V35 that year. The panel
work was done by http://www.jaair.com .
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
you look forward to the trip.
Old February 17th 04, 03:39 AM
Ben Haas
"G.R. Patterson III" wrote in message ...
George Patterson
Ahhh. The blessing of owning an experimental. I am sooo happy to have
sold all my certified planes. I never want to see a 337 form, a yellow
tag or visit a FSDO again. Good luck on getting the feds to approve
anything like that.
Ben Haas N801BH.
Need gauge help/information dave Home Built 3 February 17th 04 03:39 AM
Need gauge help/information dave General Aviation 3 February 17th 04 03:39 AM
Vaccuum Pressure Gauge Al Owning 4 January 16th 04 06:26 PM
Carb Temperature Gauge fly_the_skies Home Built 6 January 14th 04 04:32 PM
Regarding Oil Temp Gauge and Line Repairable rkane33 Owning 0 September 14th 03 10:54 PM
