where exactly to put the noise filter
Old February 20th 04, 04:10 PM
Dico Reyers
Default where exactly to put the noise filter
Hi There,
We have a 1966 mooney m20e.
We're just in the process of putting in a noise filter so that it will
hopefully reduce some of the static on the radio.
I'm wondering if the filter goes between the generator and the voltage
regulator.... or if the filter goes between the voltage regulator and
the buss.
Any help would be appreciated,
Thanks...
-Dico
Old February 20th 04, 06:09 PM
mikem
Dico,
What problem are you trying to cure?
If you have "popping" type of static in your Com/Nav receiver, then you
have a bad shield on a spark plug, or poor shielding on your P-leads
where they run from the mag to the mag switch. Noise filter on the
alternator wont do anything for this...
If you have audible strobe squeal which goes away if you turn off the
strobes, ditto... This requires work in the audio wiring and possibly in
the strobe cabling .
If you have alternator howl or whine which varies with engine speed, and
goes away if you turn off the ALT field, then a noise filter installed
on the alternator is unlikely to do much, either... This means that
your audio wiring (audio panel, intercom, mic/headphone jacks) need
attention.
If you have "hash" type noise on the Com/Nav receiver, then see if it
goes away when the engine is stopped (on the ground). If it does, then
it is likely induced by mechanical vibration. Bad antennas, bad coax
fittings, radios not properly seated in the rack can cause this.
About the only symptom which installing a filter on the alternator is
likely to cure is if you have "hash" type noise when listening to
200-400Khz on your ADF receiver.
MikeM
Skylane '1MM
Pacer '00Z
Dico Reyers wrote:
Hi There,
the buss.
Thanks...
-Dico
Old February 20th 04, 06:57 PM
Jay Honeck
Hey Mike,
What's the cure for "bleed through" from one com radio to the other?
We usually keep "Com 2" tuned to our local AWOS frequency. When we're near
Iowa City, we can faintly hear it in the background through our
headphones -- even when "Com 2" or "Both" aren't selected on our audio
panel.
Of course, this isn't an issue without ANR headsets (couldn't hear it), or
when we're far enough away from the strong signal -- but it's one of those
little annoyances that always bugs us.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 20th 04, 07:34 PM
mikem
Jay Honeck wrote:
Hey Mike,
Usually "bleed through" refers to the effects of RF overload on Com2
while transmitting on Com1, or vice versa. Most audio panels contain
automatic muting circuits which completely block the audio from opposite
com reciever while the other's transmitter is keyed.
panel.
This sounds like inadequate isolation in the audio source switching of
the audio panel. Most of modern audio panels (King, PSE, RST) do not
intrisically have this problem. I think you have a PSE, which shouldn't
do this.
It is likely that your installer did something funky with the audio
wiring between Com1/Com2 and the audio panel to induce this. Could be
that the Speaker outputs of the Com radios are wired to 8 Ohm dummy load
resistors inside the audio panel. If the installer took a shortcut and
shared the ground connection from speaker-low output on the Com(s) to
the audio ground on the audio panel, it created a classic ground loop
between the speaker audio loop and the headphone output loop, thereby
creating the crosstalk. Better wiring technique might have prevented this.
Most modern Com radios dont care if the speaker outputs are terminated
into a dummy load resistor when not connected to the overhead speaker,
so it isn't even necessary to utilize those loads built into the audio
panel.
For further diagnosis, I'll bet that if you turn the volume control of
the non-selected comm radio down, then the bleedthrough will go away.
Also try switching the non-selected com receiver to the overhead speaker
while listening to the primary com on the ANR headsets, and report back.
MikeM
Skylane \1MM
Pacer \00Z
Old February 20th 04, 09:47 PM
Nathan Young
On Fri, 20 Feb 2004 17:57:10 GMT, "Jay Honeck"
Hey Mike,
panel.
Jay - what make/model are the COM radios in your plane?
-nathan
Old February 21st 04, 12:09 AM
Jay Honeck
do this.
Actually, I have a Narco CP-136 audio panel.
(See a picture of this model at http://www.ronhahn.com/Hawk-XP/CP136.html )
Yep, I believe it does. So this means the audio panel is wired incorrectly?
Okay, will do. I should expect to hear the AWOS broadcasting quietly on the
speaker, I presume, same as I hear in my headset?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 21st 04, 12:11 AM
Jay Honeck
Com 1 is a brand new Narco 810-R, digital. (It's the slide-in replacement
for the Com 120)
Com 2 is an old-but-perfect Narco 120.
Both work flawlessly.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 21st 04, 12:33 AM
Nathan Young
On Fri, 20 Feb 2004 23:11:27 GMT, "Jay Honeck"
for the Com 120)
Hi Jay,
Take this with a caveat as I am a digital engineer who likes to learn
about RF stuff. I could be in left field here...
I asked because I was trying to determine if the radios utilized the
same IF frequency (which they would if it is the same radio). I don't
know enough about the Narco 810 or 120 to determine if they share the
same IF.
Where I was going with this...
The bleedthrough might be leakage from the IF section of one radio
coupling into the IF of the other radio. That would explain why the
audio is only noticeable as you are near the AWOS transmitter, where
the energy entering the IF stage on COM2 would be strongest.
An interesting test would be:
1. Shut off COM2 on the audio panel
2. Fly to a distant location where you can't hear the bleedthrough.
3. Turn on the audio for COM2
4. Can you hear the AWOS over the audio panel?
If you can hear the audio, then I suspect the audio problem is related
to the radio and not the audio panel (or audio wiring).
-Nathan
Old February 21st 04, 01:36 AM
MikeM
do this.
I do not have any experience with these, so the lack of isolation could be
a shortcoming of the design.
It just means that the bleed-through is happening at audio frequencies; not by
one IF coupling to the other IF as another poster postulated.
Yes, but try to determine if the faint feedthrough you hear in your headphones
is reduced by routing com2 to the speaker. It will be a subtle difference,
because the speaker audio will leak into your headphones accoustically. If the
feedthrough is reduced, then my speculation about the dummy load resistors would
warrant more investigation.
MikeM
Skylane '1MM
Pacer '00Z
Old February 21st 04, 03:24 AM
Jay Honeck
I don't think I've got enough information here. What position would I have
the audio panel in for this test? Com 1, Com 2, or Both?
And, assuming Both, what do you mean when you say "Can I hear the AWOS over
the audio panel?" Do you mean on the speaker? Or in my headphones?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Small plane noise is destroying my life Robert Morien General Aviation 5 December 1st 04 06:01 PM
K&N Performance Gold Oil Filter? MikeremlaP Home Built 0 September 3rd 04 06:58 PM
Plasma Reduces Jet Noise (Turbines?) sanman Home Built 1 June 27th 04 01:45 AM
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! Bill Mulcahy General Aviation 3 October 1st 03 06:39 AM
Airwolf oil filter system kevin Owning 3 August 7th 03 05:24 PM
