Call Autopilots Central in Tulsa and make an appointment to get it
fixed correctly. On Mon, 1 Mar 2004 10:07:19 -0500, Peter R. wrote: Speaking of the S-Tec 60-2, I am transitioning to a Bonanza V35B that is equipped with this AP. The previous owner demonstrated an idiosyncrasy with the AP that I would like to correct, if possible. Using the AP to hold VSI, the aircraft is in a climb. Upon reaching the assigned altitude, I push the ALT button on the AP. The aircraft, since it overshot the altitude by 100 feet or so, descends and levels off at the altitude where I engaged the ALT hold, then begins a speed increase to cruise speed. Now for the idiosyncrasy: The AP is engaged and the aircraft is holding perfectly at the desired altitude. However, if I disengage the AP, the aircraft immediately begins a climb, suggesting that there is a slight nose-up trim situation that was being held back by the AP. To overcome this, the previous owner suggested that after level-off, disengage the AP, manually re-trim, then re-engage the AP. How can the S-TEC AP be adjusted to hold the altitude after a climb without the nose-up trim problem? It seems to me that, over time, this problem could result in premature wear and tear of the AP control servos, no? |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 03:34 PM |
| Hold "as published"? | John Clonts | Instrument Flight Rules | 83 | November 13th 03 04:19 PM |
| GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 01:39 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
