Jim, Whelen is the way to go. No questions. They come in two flavors for the
application you seek. I used the more powerful ones and boy do they light up the sky! You WILL be seen. Very easy to install if your plane is pre wired. Any questions please feel free to ask. They are STCed for almost all GA aircraft. Mani "Jim Weir" wrote in message ... I know this subject has been covered in the rec.aviation.* ngs in the last couple of years, but my dejasearch turned up dry. I'm putting wingtip strobes on the 182 and I'd like recommendations from the group as to what you put on and why. I'd like individual power supplies for each strobe mounted out in the wingtip (last wing rib) so that I don't have to run a separate wire for nav lights and strobes, nor run a high voltage wire down the wing to act as a 15 foot noise generating antenna. Comments appreciated. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
| Thread Tools | |
| Display Modes | |
| paint shop recommendations wanted (SE) | Stephen N Mills | Owning | 0 | January 29th 04 04:44 PM |
| LEDs with Strobe lights | pekka1510 | Home Built | 11 | September 1st 03 12:36 AM |
| Red lens for Hoskins Strobe wanted | Terry | Aviation Marketplace | 0 | August 7th 03 12:11 AM |
| Red lens for Hoskins Strobe wanted | Terry | Owning | 0 | August 7th 03 12:10 AM |
| Red Lense for Hoskins Strobe Wanted | Terry | General Aviation | 0 | August 7th 03 12:10 AM |
