Removing old antennas
Old March 18th 04, 03:36 AM
Roy Smith
In article iI76c.32458$_w.542610@attbi_s53,
"Jay Honeck" wrote:
Is it worth the bother?
We're coming up on our annual inspection in May, and there are at least four
antennas on our bird that do nothing. I'll bet there's a few feet of cable
going to each one, too.
Does removing an antenna net you any extra speed, or is it mainly a weight
reduction thing?
Antennae increase drag (especially when they're attached to bugs
squashed onto the leading edge of the wing). So, yes, removing them
should result in increased airspeed. The big question is, "how much".
I think the answer tends to be "less than you'd hope".
One good clue is to read the optional equipment supplements in most
POH's. They'll typically list a half dozen different radios that could
be installed, each with their own protuberance on the outside.
Generally, under "performance changes" they'll say something like "no
significant change".
You've really got two choices. You can spend a lot of time and money
doing really careful performance measurements before and after and see
if removing them really made any difference. Or, you can just pay the
guy to take them off and be happy in your believe that you've made the
airplane faster. It certainly won't make it any slower.
Removing water repelent from fiberglass lay-up? Roger Home Built 2 December 3rd 04 12:15 AM
Do ADF antennas need replacing if changing the receiver? [email protected] Owning 5 December 11th 03 11:13 PM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 03:51 AM
Hidden Antennas Dick Goff Home Built 2 August 20th 03 06:23 PM
F-14 squadrons removing refueling cover plate? dave999 Military Aviation 7 August 6th 03 10:45 AM
