#11
![]() "Tim Ward" wrote in message ... Get a little o-ring that just slips on and slide it on before attaching the connector. Put heat-shrink over both the cable and the o-ring. You could do some coding with this -- no bumps vs 1 bump vs 2 bumps. Tim Ward I like this. I was going to suggest a thin strip of 3M stair tape (like wing-step tape) under the shrink wrap as a braille-lite device but the o-ring is simpler and much more versatile. I'll be stealing this idea immediately. ![]() |
On Sun, 01 Feb 2004 01:19:22 GMT, Orval Fairbairn
wrote: BTW, it DOES make a difference if you hook up the comm antenna to the nav and vise-versa. One is horizontilly polarized while the other is vertically polarized. Both receiver sensitivity and xmit capability cna be severely compromised. Yes, but: The Narco "Comm" antenna is the transmitter, and the "Nav" antenna provides the signal for the receivers for BOTH the Nav and the Comm channels. The Comm receiver is *supposed* to use horizontally-polarized antenna. I know, it ain't right optimum. But that's the way Narco wants it. The original two antennas in the airplanes were coax dipoles with baluns. Both horizontally oriented, both located UNDER the aluminum-covered turtledeck. They were truly duplicates. And they worked quite well, for almost 20 years. One crapped out a few years back, and that's when I built the surface-mount antenna described in my "Antenna Madness" posting about three years ago. So I've got one horizontal, and one vertical. I try to hook the old dipole (the horizontal one) to the receiver and the new vertical one to the transmitter. I actually run the coaxes in two pieces, with the connector right by the seat, so I can switch antennas easily if I detect a problem. This is handy for troubleshooting...a couple of times, I've noticed that I wasn't receiving signals very strong, or folks complained that they couldn't hear me very well. I've been able to quickly swap antennas and compare. Ron Wanttaja |
On Sat, 31 Jan 2004 17:40:32 -0800, "Tim Ward"
wrote: Get a little o-ring that just slips on and slide it on before attaching the connector. Put heat-shrink over both the cable and the o-ring. Oooo, I *like* this one. Smooth and elegant. I'm kinda in a anti-tie-wrap mood today, so am not too inclined to use them for the tactile feedback. I think y'all will understand why: Since I had to pull my avionics box to install the new transponder in it, I decided to try to sort out the existing wiring. Scary. REAL scary. I cut off at least a dozen tie-wraps getting things opened enough so that I could at least look it over. There was one wire about eight inches long that had *four* crimp splices along its length. There were three separate connectors between the power bus and the old transponder, including one that had extra wires S'ed atop it and the whole thing covered with a plastic spiral wire loom (in other words, I didn't even *know* there was a connector there until I'd unwrapped everything. I'd post pictures, but don't want to give Jim Weir a heart attack. :-) The good news was that the main connector running from the power bus had masking tape with the color assignments for the wires marked on it (still legible after ~10 years). The bad news is that I had to get used to the WHITE wire being the ground. The encoder is located about eight inches from the transponder. Unfortunately, the transponder had come with a full yard of cable to the encoder, and the installer left it all in place. Some extra was needed; eight inches as the crow flies would take it right across the rudder pedal tunnel. The cable has to go up about four inches to a top-fuselage crossmember, cross the tunnel area, and down about six on the left cockpit sidewall. To "use up" the excess cable, the installer ran it up to the crossbar, RIGHT almost to the right cockpit sidewall, then loop all the way back to the left sidewall and down. Tie-wrapped in place, of course. Even more fun, a pair of 18-gauge wires were tie-wrapped to the transponder cable, splitting off on that furthest right loop. I traced it to the bottom of the instrument panel, and it seemed to disappear into the headset cluster. I traced the OTHER ends, and it bypassed the radio completely...not part of the headset, then. I finally found the far ends of the wire. They terminate in some sort of power jack that I didn't even know I had. Think the previous owner used it to power up his LORAN. In all honesty, I don't completely blame the installer, and even must put some of the blame on myself. Until last September, it was almost impossible to access the electronics on my airplane. All of this wire bundle is far forward of the seat, in the "tunnel" of the forward cockpit. Either you had to sit in the seat and jackknife forward (the electronics were around your ankles), or remove a floor access panel forward of the area and try to reach into the fuselage; when sitting on the ground, the area is just within arm's reach. Neither was comfortable for more than a minute or two. I had to go through this when I had to replace my Comm radio when the frequency standards changed, hence the new Comm radio connections were done expediently if not necessarily neatly. This changed last September, when the plane was going to be laid up for a while for a dry-rot repair and I figured I'd fix a few other things at the same time. I posted the whole horrid tale to the Fly Baby mailing list, but, in short, I cut out a 1' x 3' section of belly fabric and installed an aluminum inspection panel. Not only does this give me access to areas of the cockpit I could barely reach before, but I can now sit on the seat longerons and dangle my legs out the hole in the belly. Makes it a LOT easier to reach the electrical stuff. The only drawback is people keep yelling "Yabba-dabbo-do" when they see me sitting in the airplane with my feet touching the ground. Ron "Do the foot-launch rules still apply" Wanttaja |
![]() "Ron Wanttaja" wrote Not only does this give me access to areas of the cockpit I could barely reach before, but I can now sit on the seat longerons and dangle my legs out the hole in the belly. Makes it a LOT easier to reach the electrical stuff. The only drawback is people keep yelling "Yabba-dabbo-do" when they see me sitting in the airplane with my feet touching the ground. Ron "Do the foot-launch rules still apply" Wanttaja LOL I love your writing. When you gonna write another book? -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.576 / Virus Database: 365 - Release Date: 1/30/04 |
On Sun, 1 Feb 2004 13:56:31 -0500, "Morgans"
wrote: I love your writing. When you gonna write another book? Thanks! Writing has been taking second fiddle lately, since I've been so busy at work (it's tough to come home and face the computer after spending all day on it). However, both KITPLANE CONSTRUCTION and AIRPLANE OWNERSHIP are due for new editions, so I'll probably be working on those. Been holding off to when all the Light Sport Aircraft stuff is official. I've been posting my Fly Baby stuff to the Fly Baby mailing list instead of RAH, but some of it gets archived on my web page. Go to: http://www.wanttaja.com/flybaby ....and click the "Stories" link. A couple of RAH denizens feature in one such piece, at: http://www.wanttaja.com/flybaby/dunderbirds.HTM Ron Wanttaja |
On Sun, 01 Feb 2004 20:08:19 GMT, Ron Wanttaja
wrote: On Sun, 1 Feb 2004 13:56:31 -0500, "Morgans" wrote: I love your writing. When you gonna write another book? Thanks! Writing has been taking second fiddle lately, since I've been so busy at work (it's tough to come home and face the computer after spending all day on it). However, both KITPLANE CONSTRUCTION and AIRPLANE OWNERSHIP are due for new editions, so I'll probably be working on those. Been holding off to when all the Light Sport Aircraft stuff is official. I've been posting my Fly Baby stuff to the Fly Baby mailing list instead of RAH, but some of it gets archived on my web page. Go to: http://www.wanttaja.com/flybaby ...and click the "Stories" link. A couple of RAH denizens feature in one such piece, at: http://www.wanttaja.com/flybaby/dunderbirds.HTM Ron Wanttaja Feature??? I'm not sure "feature" would be the appropriate word but... My last mistake of the day happened a few minutes later. John Ousterhout and John Ammeter came around, and complimented me on the display. I was feeling a bit better about our effort, by then. "Maybe they had to use a wide-angle lens to shoot our picture," I said proudly, "But our formation…." I didn't get any farther. On the phrase "our formation," both Oyster and Ampmeter starting howling with laughter. Some friends *I* got. :-) Ron "Dunderbird One" Wanttaja I do have to say that our response to Ron's use of the word "formation" was completely unrehearsed and totally spontaneous and, I might add, we both burst out in laughter at the same instant.... Formation?? Much more like "same day, same destination"... John A |
