Of clocks and learning curves...
Old June 16th 04, 06:17 AM
David Lesher
Easy way to do this is two diodes. Common is the clock in.
One from the master switch hot; the other from the avionics hot.
When the master is off, that 13.8v supplies the clock. When it's
on, the avionics bus is hot.
No wire-stringing needed.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
