Aaron Coolidge wrote in message ...
Kent Shaw wrote: : I had all kinds of problems with the starter on my Piper Warrior and : had to spray Bendix with silicon before every start. I finally : replaced it with one of the new lightweight starters and couldn't be : happier. Easy installation and you may get your A/P to signoff on : your work. A followup to my original post: I have now figured out exactly how the starter bendix drive works, and why it stays extended even when not turning, after it has been extended. There are 2 little spring loaded pins that hold the bendix drive out, which are arranged so that at high RPM their weight + centrifugal force retracts them, allowing the pinion to retract as well. Apparently one of these pins is dragging on my unit. I have in my hands a new EBB-131A starter drive which I intend to install tomorrow, which should solve this problem. The guy at Sacremento Sky Ranch who sold me this EBB-131A said that it was his last one, and the last "US-made" one. New ones are imported from India, and he said there have been several recalls already. Further bulletins as events warrant... The pins are OK, since the thing is retracting. There's a broken spring inside the drive: a spring that pushes and keeps the gear back out of the way when the pins retract. Same outcome: replace the drive. Dan |
| Thread Tools | |
| Display Modes | |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 04:13 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 08:00 AM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 08:17 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
