Strange engine event
Old July 6th 04, 02:55 PM
Jim Carter
Dave,
I've torn engines down before and the distance between the rings is
relatively a lot more than the gap between the ends of the ring when
compressed into the cylinder. It is such a big difference that I don't see
how the intra-ring distance could be restrictive to the flow of gasses
passing through the ring gap.
I'd really like to see some information on the "Very Clever Design" you
mentioned. Even if the cylinders were honed with a diagonal pattern,
shouldn't the ring just reverse direction at the end of the stroke and
follow the honing marks?
Jim Carter
"David Lesher" wrote in message
"Jim Carter" writes:
What causes the piston rings to rotate? Since the piston movement is
perpendicular to the cylinder wall, there must be some other mechanism
other
than just piston movement causing them to rotate.
Very Clever Design. I can't recall the details, but ISTM there are
[automotive] patents on making 'em creep along.
Also, why would the grooves on the rings have to be lined up to allow
leakage through the groove?
It does leak lots more; the gap between the rings is not all that
far, I guess...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 02:41 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
