Strange engine event
Old July 7th 04, 03:43 AM
David Lesher
"Jim Carter" writes:
I've torn engines down before and the distance between the rings is
relatively a lot more than the gap between the ends of the ring when
compressed into the cylinder. It is such a big difference that I don't see
how the intra-ring distance could be restrictive to the flow of gasses
passing through the ring gap.
I'd really like to see some information on the "Very Clever Design" you
mentioned. Even if the cylinders were honed with a diagonal pattern,
shouldn't the ring just reverse direction at the end of the stroke and
follow the honing marks?
Jim Carter
"David Lesher" wrote in message
What causes the piston rings to rotate? Since the piston movement is
perpendicular to the cylinder wall, there must be some other mechanism
other
than just piston movement causing them to rotate.
Very Clever Design. I can't recall the details, but ISTM there are
[automotive] patents on making 'em creep along.
Also, why would the grooves on the rings have to be lined up to allow
leakage through the groove?
It does leak lots more; the gap between the rings is not all that
far, I guess...
I don't recall much more. I'll ask a friend who knows lots more
than I do on engine innards. But it was Detroit, not overseas...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
  #32
Old July 8th 04, 10:34 PM
The piston really only approximately goes straight up and down.
Engines are not perfect machines. If you looked at the general
dynamic alignment of everything on the microinch level etc, there is
probably a slight amount of rotation inherent in the structure of an
engine including the crankshaft and rod deformations. When combined
with the varying pressure fluctuations on each ring, the ring
gradually rotates
in one direction or another. Remember you are dealiung with something
that is cycling back and forth 40 times per second, so that it doesn't
take very much rotation each cycle to give a lot of eventual motion.
Put it another way - why shouldn't it rotate?
  #33
Old July 9th 04, 01:10 AM
Jim Carter
I don't think it should rotate because the action of scrubbing against the
cylinder walls will wear "micro" grooves in the rings that match up against
corresponding ridges on the cylinder wall. If the rings rotated there would
never be this ridge/groove result. Since you can see and sometimes feel the
grooves and ridges, I can only assume the rotation of the ring is not
happening.
Jim Carter
om...
  #34
Old July 9th 04, 04:42 AM
Orval Fairbairn
happening.
That is why cylinders get a crosshatch pattern during the honing
process. The microgrooves go around the cylinder, not parallel to its
major axis.
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 02:41 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
