Wet vac pump question
Old July 11th 04, 03:10 PM
Rip
Wet pumps have no seals, per se, and in fact get their lubricating oil
from the accessory pad they are driven from. On many engines this means
that the seal is removed from the drive pad. Internally, the pumps have
either steel (ARO), or heavy graphite (Pesco, Garwin) vanes that do
eventually wear out, but you would tend to see this wear indicated by
poor vacuum, rather than extra oil. The typical "output" of these pumps
is a lot of air with a fair amount of oil entrained, almost like the
spray from an aerosol can. The engine breather vent should have almost
no oil at all, and at extremely low pressure (inches of water, rather
than PSI). Unfortunately, most air/oil separators don't do a very good
job. I've tried 4 or 5 different units, and only the Airwolf did what it
was advertised to do.
JFLEISC wrote:
In my continuing effort to plug all the oil leaks in my Continental 0-300 I
have a final question about wet vacuum pumps. How much oil out the vent is too
much? This is a '61 C-172 with the factory standard oil recovery system off the
wet vac. About twice as much oil comes out the vacuum vent as out the engine
vent. Is that normal and if not what is the fix? Are there seals in the pump
that wear out or something? Any info would be appreciated.
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 06:17 PM
Windmilling Prop & Vacuum Pump Matt Young Instrument Flight Rules 14 October 14th 04 09:08 PM
Wet Vacuum Pump smackey Owning 6 February 24th 04 08:03 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 08:09 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 01:35 AM
