"Mike Rapoport" wrote: More oil does not improve cooling. If you think about it, it makes sense. Where would the additoinal heat go? Same oil cooler, same cooling fins, same baffles producing the same airflow. The oil will actually be hotter... ....so the delta T of the oil cooler-to-air will be greater and the rate of heat transfer will will be increased, no? Thus more heat will be removed from the engine. -- Dan C172RG at BFM |
| Thread Tools | |
| Display Modes | |
| Air/Oil separator Best one for $ | Ron | Home Built | 1 | September 27th 04 01:10 AM |
| FA: AIRWOLF WALKER AIR/OIL SEPARATOR AFC-W315 - NEW | Mike Ferrer | Aviation Marketplace | 0 | August 29th 04 02:56 AM |
| FA: Airwolf / Walker Air-Oil Separator | Mike Ferrer | Aviation Marketplace | 0 | August 23rd 04 09:15 PM |
| Questions regarding Air/Oil Separators | Doodybutch | Owning | 6 | April 20th 04 06:56 PM |
