Have had the problem in a C-150 and it was bugger to figure out.
To start with I've had a lot of experience with Cessnas having had a full line Cessna shop during the late 60's. I am an A&P with AI endorsement at the time. I only state this to let you know that I've had some background with the aircraft. I bought a 75 C-150 in the early 80's in California. Nice clean aircraft, ran and flew very nicely. I had flown the airplane maybe 20 hours before one morning departed for Las Vegas, if you know Ca. you know that means going high because of the mountains. Well, during the climb at about 8000 ft the engine quit just as if the mixture control had been pulled. Went through all the normal checks but could not get a restart. Notified approach and set up a glide for the nearest airport. At around 4-5K the engine restarted on it's own. I completed a normal landing and thoroughly check the engine over. Everything checked ok and after power checks took off completed the flight. To try to make this short let me just say that in the next couple of months I had 5 or 6 more engine outs all while in a climb at around 6-9 thousand feet. It got so that it didn't even scare me anymore because it would always restart after descending 2-3 thousand feet. It was obvious that it was fuel starvation but why? I went through the service manual and checked everything I could think of. Fuel cap vent, main tank vent behind strut, fuel lines, carb and main fuel strainers, etc. I did the vent checks call out in the manual plus a few more that Cessna engineers wanted after consulting with them. Everything check ok, or so I though. I was at a loss. But one day while I was doing a preflight I happen to pull a little harder than I normally do on the main vent behind the left strut and the vent line popped down. This is the line that makes a 90 degree turn forward to catch ram air to slightly pressurize the tank in flight. I then notice that the paint line where it comes out of the wing was now even with the bottom of the wing. This is where the line was when the aircraft was originally painted. Sure enough the line had been pushed up in the wing, only about a half inch from its original position. I had checked this dimension before but it's very difficult to get an accurate measurement on the centerline at the bend. The moral to the story is that this dimension is critical. The vent is placed behind the strut to minimize the chance of impact icing since it's not heated. Turns out that the strut is somewhat of a airfoil and when the vent is too high above the strut it puts it on the low pressure side during a climb. As I'm sure you know you have to keep increasing the angle of climb at higher altitude to maintain a climb and this puts the vent more into that low pressure region. You reach a point where this actually will start pulling air from the tank and when it reaches a flow that the fuel cap vent cannot match you get negative pressure and engine stoppage. You then drop the nose during the descent putting the vent back in positive pressure and eventually the engine restarts. Sorry for so long but that's the story. Cessna and I both learn something from this one. Bill... wrote in message om... I have had that vapor lock (I think) happen in a 1967 172 leveling off after a long climb to about 8500 ft. It was dead smooth air during the climb. We were speculating that maybe the under-the-floor temps are high and if the coordination happened to be such that the fuel flow went to near zero for an extended time in one of the tank lines to the fuel selector. We had forgotten to switch from both to one tank above 5 thou. I understand Cessna had a hard time duplicating the problem after from the few field reports that came in before the AD was issued. They never published a reason for it as far as I know. There was a total power interruption for maybe 20 seconds while the two of us (both engineers) franticly tried to figure out what was happening while we were over northern Wisconsin near night. The last thing was pulling the fuel quick drain although I don't know if that was the fix or if the problem corrected itself via other means. It definitely was a fuel starve out type failure and not a flooded out type of failure. We most certainly were leaning for the climb at that altitude. We had EGT and we always monitored it. Has anyone else encountered this stumble? Could it really happen to be the dead smooth air and the coordination? |
| Thread Tools | |
| Display Modes | |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
| Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 08:48 AM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
| C210 fuel tank vents | Eric Brown | Owning | 2 | September 27th 03 03:59 AM |
