Jay,
I put them on my Six back in '97. They are great, especially on a Six since the pavement illuminated by the stock nose light is mostly obscured by the long nose. Yes the parts are cheaper than the replacement tips, but you'll make up the difference in the install labor. As I recall, the install was about 20 hours. They come with Q4509 lamps, which last a long time in the tips. I've only replaced one bulb in some 800 hours, and I have them on flash on every flight. My install is a bit unique. The lights come with a split rocker switch that is marked L and R, intended to connect to each wing light so you can control them independently. The recognition flasher comes with an additional switch, and it essentially connects electrical switches in parallel with the L and R switches. If you follow the STC wiring, you have to add two new switches to your panel. On mine, we added a pair of Piper relays under the seat in place of the L and R switches in the supplied connection diagram. The L-R switch supplied was put in the panel in the place of the original landing light switch. The L side is connected to the existing nose light circuit, and also to the coil on both of the added relays so that when L is on, all 3 lights come on (L=landing light). The R side of the switch is connected to the recognition flasher box, so when it is on and the L side is off, the wingtips alternate and the nose remains off (R=recognition). Each light has it's own pullable breaker so I can individually turn off lights if I need to (although the nose light has to be on to turn on the wing lights since the nose circuit powers the relays). The advantage is one switch operates all the lights and there are no new switch holes to make in the panel (the split L-R rocker switch matches the original grey rocker switches in size and shape). Jay Honeck wrote: Has anyone had any experience with the 'skylight' brand of wing lighting? I have never heard of it until today when I saw it in a flyer for Cherokee Pilots Assoc. I have been looking at wingtip lighting... but it's pricey. The skylight lighting is mounted into the leading edge, rather than the wingtips and is about half the cost of the wingtip set up. Thanks. They are a popular option for Cherokee Six, Pathfinder and Dakota drivers, cuz our wing-tip gas tanks preclude the installation of the more common wingtip landing lights. I've been eying them longingly for the last couple of years, but have never actually spoken with anyone who has them installed. The guy who makes them is apparently very "old school," and he has neither email nor a website. But the price is sure right. I'd be interested in hearing from anyone who has experience with them, too. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
| Thread Tools | |
| Display Modes | |
| Osan’s 51st Fighter Wing to get its own coin | Otis Willie | Military Aviation | 0 | April 5th 04 11:44 PM |
| ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 09:40 PM |
| Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 04:40 PM |
| Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 03:33 AM |
| The Piper Cubs That Weren't | Veeduber | Home Built | 5 | August 28th 03 05:38 AM |
