Garmin 430 Reception
Old November 2nd 04, 04:27 AM
David Lesher
Jon Kraus writes:
Our "new" '79 M20J came with a 2 year old Garmin 430 GPS and Garmin 340
audio panel. The backup radio is an ancient King 170B. I must say that
the reception on the Garmin sucks compared to the 170B. Am I doing
something wrong or is this just something I have to live with? To me for
10 grand the Garmin should run circles around the 170B . Thoughts?
Don't flame me too bad I have only flown this plane a couple of
times... Thanks!!
Can you swap the antennas around? There is no receiver made that
does not need a good antenna.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old November 3rd 04, 12:09 AM
Jon Kraus
I agree Jim.... Thanks for the great advise!!! JK
Jim Weir wrote:
Painting the antenna with anything other than a metallic-based paint (very rare)
will have no measurable effect on the antenna. Stop changing out parts and
start measuring. Any avionics shop worth a damn will have either a Bird b-d
wattmeter or a VSWR meter. I prefer the Bird, but anything is better than
guessing.
Jon Kraus
-Good idea.... For some reason in '98 when they painted the aircraft
-they thought painting the antenna's was a brilliant idea too.... Maybe
-that has something to do with it and the 170B handles it better.. JK
http://www.rst-engr.com
Old November 3rd 04, 08:40 PM
James M. Knox
Aaron Coolidge wrote in news:cm4ceq$d31
I just flew a '77 Arrow with a 430 and a KX170B. The reception on the
170B was FAR superior to that on the 430. I think that the old-timers
that designed the 170/175 radios really had a handle on how to take care
of low signal strength inputs, while the 430 designers copied the TI
databook for a "118 to 135 MHz aircraft transmitter/receiver".
Beyond that, the antennas can make a big difference in how a receiver
performs.
Very true, but still the difference is real. My '77 Arrow has a KX170B and
a GX-60 (now also Garmin). The KX170B is good for another hundred miles
over the GX-60. In my case it's definitely not the antenna, but the
squelch. Many times ATC will not come in, or will come in very broken.
Pull the squelch and they are loud and clear. Switch to the KX-170B and it
works beautifully.
I questioned UPSAT if the GX-60 squelch could be adjusted and was told a
blunt "NO, it's fixed. Go away."
jmk
Old November 4th 04, 01:32 AM
Dave Anderer
I put a 430 in about 4 years ago, and kept a 170B as the 2nd radio. Can't
say I've noticed any difference between them in reception. Both are
"fine" to my ears.
Old November 4th 04, 07:40 PM
Maik
hi
performs.
works beautifully.
My experience with the UPSAT guys is diefferent. They were very responsive.
In the installation manual of the GX-60 you will find a way to adjust
the squelch.
Send me a mail if you don't have it.
Maik
Old November 6th 04, 04:12 PM
James M. Knox
Maik wrote in :
told a blunt "NO, it's fixed. Go away."
responsive.
the squelch.
I have the manual, and it is NOT in there. I wonder if it is a capability
that they added in the newer units.
What version of the GX-60 is yours? [Mine is something like 2.4]
jmk
Old November 7th 04, 04:17 AM
PaulH
I checked my 430 against my KX125 today on the ATIS and the 430 picked
up the ATIS 60 miles out, about 10 miles before the KX125. My
installer strongly recommended new cables and antenna when the 430 was
installed, and it's always been excellent.
Garmin 430 VOR reception Maik Owning 7 September 30th 04 04:49 PM
Garmin 430 VOR reception Maik Instrument Flight Rules 3 September 30th 04 04:48 PM
Garmin 296 worth the money? Terry Owning 15 June 22nd 04 10:03 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 03:04 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 10:04 PM
