Glue for wing step grippy thingies
Old November 26th 04, 10:32 PM
Steven Barnes
Default Glue for wing step grippy thingies
A corner of the wing step "tread" is peeling up on my Cherokee 180. Is there
a particular glue or epoxy to use/stay away from? I can just see a big
chemical hole being eaten right through my wing... ;-)
Thanks!
PP-ASEL, instrument
Old November 26th 04, 10:42 PM
zatatime
On Fri, 26 Nov 2004 21:32:53 GMT, "Steven Barnes"
Thanks!
There's stuff made for that specifically. I think it's calle Wing
Walk. Spruce will have what you need.
HTH
z
Old November 27th 04, 12:27 AM
Michelle P
Steve,
Is it strips or one "piece"?
if it is one piece it was painted on wing walk compound.
Strips 3M Scotch 1300L.
Michelle
Thanks!
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old November 27th 04, 02:39 AM
Steven Barnes
It's like 2 pieces. Each about 2.5 feet long & 1.5 feet wide. They "overlap"
a bit right in front of the door jam. Where the top/front one lays on top of
the bottom/back one, it's rolling up a bit on the outside corner.
I've got a billion pics of the plane but no good ones of the wing tread.
"Michelle P" wrote in message
k.net...
Steve,
Michelle
there
Thanks!
Old November 28th 04, 02:28 PM
Nathan Young
I just had my Cherokee painted this summer. They used a single-piece
wing walk. It had the adhesive already installed - just had to clean
the surface, peel, and apply.
-Nathan
Old November 28th 04, 04:52 PM
Mike V.
"Nathan Young" wrote in message
there
.... and then you end up with peeling problems on the wing walk. The stick on
wing walks are crap, they tend to peel. They should be painted on...
Old November 28th 04, 10:56 PM
Nathan Young
there
Time will tell. 4 months and all is well
