Aircraft storage
Old December 18th 04, 09:55 PM
#1ACGuy
Default Aircraft storage
How long can an aircraft sit unused before the fuel gums up and contaminates
the fuel system?
For instance, if I leave a motorcycle sit too long without a fuel stabilizer
added to the gas, the gas goes bad after a few months and gums up the carbs.
The entire fuel system is affected after a while. Big problem if you try to
store an automobile without lots of prep since fuel lines and everything can
gum up.
What is the life of av gas before it goes bad?
If it's like white gas it can sit almost indefinately. If it's like auto
fuel it can't sit for long.
I ask because some of these planes seem like they're for sale for over a
year or more, and I wonder what kind of problems they have due to sitting
besides the obvious dry startup with no oil on the cam etc. (as if that
isn't enough of a problem)
Alex
My 2¢ YMMV
Old December 18th 04, 11:15 PM
G.R. Patterson III
uhhh..... white gas is a type of unleaded auto gas.
George Patterson
The desire for safety stands against every great and noble enterprise.
Old December 19th 04, 12:11 AM
#1ACGuy
"G.R. Patterson III" wrote in message
It may be, but it's much more highly refined and can store for much, much
longer than unleaded auto fuel without gumming up. Auto unleaded will only
store for months, white gas may be good for years.
George Patterson
enterprise.
Old December 19th 04, 12:16 AM
G.R. Patterson III
#1ACGuy wrote:
Auto unleaded will only store for months ....
I've been running my 1940 Ford on the same tank for three years now (obviously I
don't take it anywhere -- just run the engine a while).
George Patterson
Old December 19th 04, 01:55 AM
Matt Whiting
It isn't a type of unleaded auto gas, it is a type of naphtha, which
isn't gasoline and isn't benzene, but is between the two in the
distillation process.
Matt
Old December 19th 04, 02:38 AM
G.R. Patterson III
Maybe in some circles, but Amoco unleaded gasoline has been called "white gas"
in the South (at least) since I was born (also at least). It's called that
because it's clear.
George Patterson
Old December 19th 04, 03:12 AM
Matt Whiting
because it's clear.
I won't dispute that, but still doesn't make it so. I can call a Ford a
Chevy also, but it doesn't make it so.
Matt
Old December 19th 04, 05:04 AM
G.R. Patterson III
Your opinion, but mine is that better than half a century of common usage *does*
make it so. White gas is unleaded car gas.
George Patterson
Old December 19th 04, 05:48 AM
George Patterson
Its a regional thing.
I've never heard anyone refer to any kind of car gasoline as white gas in the
southwest; white gas goes in camp stoves (or used to before propane took
over).
Jim Pennino
Remove -spam-sux to reply.
Old December 19th 04, 07:13 AM
Jay Beckman
a
*does*
George Patterson
enterprise.
over).
Jim Pennino
Jim,
Same terminology where I grew up in Michigan. White gas = Coleman.
Jay Beckman
PP-ASEL
Chandler, AZ
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
